> A different way to hook up 911 e-brakes, Another way to do the 911 parkbrake -merged threads
Wes V
post Oct 4 2008, 07:07 PM
I think I've come up with a totaly new way to hook up 911 parking brakes. It involves making up longer hybrid cables.
It's not complex, doesn't cost tons, and is about as straight forward as possible.
It functions exactly as intended in the 911.
Here is a teaser photo;
(IMG:http://www.performanceforum.com/wesvann/914a/my-rear-brake/b-mrb1.jpg)
Here is a link to my write-up on how I did it (it's a preliminary write-up).
hybrid cables
Wes
(can somebody please find me the photo that I've seen on this site where somebody used a cable end block at the parking brake lever that had set screws)
Richard Casto
post Oct 9 2008, 03:16 PM
Blue Sky Motorsports, LLC
I think another way to say what Eric is saying is...
While you have the pins that keep the shoes attached to the backing plate, pretty much the shoes, spreader and adjuster pretty much float. If you didn't have what we are calling the "stop block" or "spacer", if you engaged the e-brake and tried to move the car, it would either rip the pins from the backing plate or break the pins as the shoes, spreader and adjuster rotated with the disk/drum and the backing plate remained stationary. You also wouldn't rotate much before your cable broke or yanked the spreader out from between the two shoes.
So while the spreader moves them apart, most likely one or the other shoe (depending upon which way the car wants to move) is in contact with the stop block. This is why in my opinion you should not weld the stop block to the thin walled 911 backing plate. And as you mention Clay the 944 backing plate it a heavier cast part and not a thin stamped part because it includes the stop block and can take the load.
The load at rest on the level is probably pretty small/next to nothing. But I think that the load is much higher if you tried to engage the e-brake while moving or if you are parked on a hill.
Wes V   A different way to hook up 911 e-brakes   Oct 4 2008, 07:07 PM
okieflyr   Sweeeeet! :popcorn:   Oct 4 2008, 07:55 PM
Wilhelm   Nice write up. What are your ideas for the parki...   Oct 4 2008, 09:53 PM
Wilhelm   Nice write up. What are your ideas for the park...   Oct 4 2008, 10:38 PM
LarryR   Very nice! I am getting ready to to the 911 br...   Oct 4 2008, 10:09 PM
PRS914-6   Nice write up. Most of us have thought of the ide...   Oct 4 2008, 11:17 PM
Larry Hubby   Clever and resourceful, Wes. Looks good! Larr...   Oct 5 2008, 03:49 AM
PRS914-6   Another thought on your idea........I don't ha...   Oct 5 2008, 08:50 AM
Wes V   The issue with the bell-crank solution is that it ...   Oct 5 2008, 11:27 AM
Wilhelm   The issue with the bell-crank solution is that it...   Oct 5 2008, 11:52 AM
Richard Casto   The 928,944, 924 mechanism requires only a pull, ...   Oct 6 2008, 12:55 PM
andys   Another thought on your idea........I don't h...   Oct 6 2008, 10:57 AM
Wilhelm   [quote name='PRS914-6' post='1087728' date='...   Oct 6 2008, 08:25 PM
jj83118   I was going to post my 911 e-brake cable solution,...   Oct 5 2008, 03:13 PM
jj83118   Another shot from the inside.   Oct 5 2008, 03:16 PM
jj83118   Welded cable end.   Oct 5 2008, 03:17 PM
Wilhelm   Welded cable end. So when you cut this cable e...   Oct 5 2008, 04:50 PM
Wes V   Welded cable end. I like this! I never th...   Oct 5 2008, 06:17 PM
jj83118   A complete cable (still need to shorten the thread...   Oct 5 2008, 03:19 PM
sixnotfour   silver solder the way to go but crimping is way m...   Oct 5 2008, 04:54 PM
ClayPerrine   This thread made me want to post this now. The pr...   Oct 5 2008, 07:06 PM
Wes V   Clay; The fact that what I did would place the sh...   Oct 5 2008, 08:09 PM
ClayPerrine   Clay; I'd have prefered that you just post t...   Oct 5 2008, 08:42 PM
jj83118   I welded the crimped ends back on with a MIG welde...   Oct 5 2008, 09:32 PM
Richard Casto   Wes, Thanks for showing how you did this. I am s...   Oct 6 2008, 12:49 PM
Wes V   This is what AndyS is talking about when he commen...   Oct 6 2008, 01:12 PM
Richard Casto   Wes, Thats pretty cool. Basically its just like ...   Oct 6 2008, 01:47 PM
Wes V   Richard; In light of the fact you can figure out ...   Oct 6 2008, 02:03 PM
Richard Casto   I am an Electrical Engineer by training, but I sti...   Oct 6 2008, 03:43 PM
Wes V   If someone wants to send me the 924/944/928 parts...   Oct 6 2008, 05:15 PM
ClayPerrine   I actually looked at the 924/944 solution. The mou...   Oct 6 2008, 09:53 PM
Wilhelm   I actually looked at the 924/944 solution. The mo...   Oct 6 2008, 10:37 PM
ClayPerrine   I actually looked at the 924/944 solution. The m...   Oct 7 2008, 07:42 AM
Wes V   (I'm glad I started this sting) Here's a ...   Oct 7 2008, 11:03 AM
Wes V   I think it dawned on me why Clay said that the 944...   Oct 7 2008, 11:51 AM
jcd914   I think it dawned on me why Clay said that the 94...   Oct 7 2008, 12:56 PM
ClayPerrine   66-68 911 park brakes are the same as the later on...   Oct 7 2008, 01:26 PM
Wes V   I formally bow in humility to Clay Perrine! :w...   Oct 7 2008, 07:09 PM
craig downs   I've been working on this also for about two w...   Oct 7 2008, 11:55 PM
craig downs   Here a little what I've done You have to remov...   Oct 8 2008, 12:05 AM
craig downs   and   Oct 8 2008, 12:07 AM
Richard Casto   Craig, Excellent job! It looks like you are ...   Oct 8 2008, 02:55 PM
craig downs   911 shoe on the left and a 944 on the right it the...   Oct 8 2008, 12:28 AM
Richard Casto   911 shoe on the left and a 944 on the right it th...   Oct 8 2008, 03:08 PM
smdubovsky   Just about every porsche other than the 911/912 ...   Oct 8 2008, 09:39 AM
andys   Guys, Keep up the good work. This thread is getti...   Oct 8 2008, 11:12 AM
Richard Casto   Just spent a few minutes looking at PET for 924, 9...   Oct 8 2008, 02:51 PM
ClayPerrine   I have had sitting side by side in front of me a 9...   Oct 8 2008, 03:09 PM
craig downs   I'm totally aware of how the backing plate is ...   Oct 8 2008, 09:04 PM
Wes V   Craig; On the prior page, jcd914 posted a photo s...   Oct 9 2008, 09:31 AM
Wes V   Craig; Here is some more "food for thought...   Oct 9 2008, 12:51 PM
ClayPerrine   In the middle of the day today a stray thought abo...   Oct 9 2008, 02:05 PM
Eric_Shea   Not sure if that's accurate. I believe they...   Oct 9 2008, 02:28 PM
ClayPerrine   Not sure if that's accurate. I believe the...   Oct 9 2008, 03:09 PM
Eric_Shea   Wait... rethinking. You're right. The spreade...   Oct 9 2008, 02:34 PM
ClayPerrine   Wait... rethinking. You're right. The spread...   Oct 9 2008, 03:11 PM
Richard Casto   I think another way to say what Eric is saying is....   Oct 9 2008, 03:16 PM
Wes V   I agree with what Richard is saying. Think of the...   Oct 9 2008, 03:40 PM
smdubovsky   If you yank on the parking brake while the car is...   Oct 9 2008, 03:52 PM
PRS914-6   Guys, you have to have a firm stop and the shoes h...   Oct 9 2008, 03:58 PM
Eric_Shea   I almost had it :lol3: The "stop" preve...   Oct 9 2008, 06:49 PM
craig downs   Lots of good information this is a fun thread and ...   Oct 10 2008, 12:53 AM
Wes V   Lots of good information this is a fun thread and...   Oct 10 2008, 09:02 AM
craig downs   Checking cable line up. Going to cut and realign c...   Oct 10 2008, 01:00 AM
craig downs   In the relaxed position In the pulled positio...   Oct 10 2008, 01:09 AM
craig downs   Mocking up a shoe stop I'll make them up this ...   Oct 10 2008, 01:17 AM
Wes V   The stop will have to have support blocks welded ...   Oct 10 2008, 09:50 AM
Richard Casto   The stop will have to have support blocks welded...   Oct 10 2008, 12:47 PM
Richard Casto   Mocking up a shoe stop I'll make them up this...   Oct 10 2008, 12:50 PM
craig downs   This show why the spreaders need rear support as y...   Oct 10 2008, 01:22 AM
Wes V   Craig; Here is an idea for you to think about; M...   Oct 10 2008, 09:23 AM
Phoenix-MN   "Are you planning on installing a "retur...   Oct 10 2008, 09:57 AM
Richard Casto   Continuing to think out loud here. I promise this...   Oct 10 2008, 01:01 PM
Wes V   Richard; I think your "drawn" diagram i...   Oct 10 2008, 01:27 PM
smdubovsky   Heres a pic of an early steel 911 arm. The late a...   Oct 10 2008, 04:05 PM
craig downs   Richard figured it out what I was trying to explai...   Oct 10 2008, 07:04 PM
Steve   I would love to do this to my car. Does anyone kn...   Jan 3 2009, 12:23 PM
burton73   Steve, You are still going to need a set of rear ...   Jan 3 2009, 06:36 PM
Steve   Steve, You are still going to need a set of rear...   Jan 4 2009, 07:57 PM
charliew   It looks to me that the aluminum arm style straigh...   Jan 4 2009, 05:27 PM
charliew   I bought some 911 rear brakes and aluminum arms on...   Jan 5 2009, 11:34 AM
Steve   I bought these parts from Parts Heaven. They do n...   Feb 21 2009, 11:13 PM
Steve   Here's the one with the bolt holes.   Feb 21 2009, 11:14 PM
craig downs   You happen to get a later year e-bake assembly tha...   Feb 22 2009, 01:42 AM
Steve   You happen to get a later year e-bake assembly th...   Feb 23 2009, 09:03 AM
jaxdream   Hi guys , I too have been wanting a 911 ebrake set...   Feb 22 2009, 11:34 AM
PRS914-6   Actually, if you have good cables the two springs ...   Feb 22 2009, 12:06 PM
scotty b   I think I still have a complete 86 944 rear suspen...   Feb 22 2009, 12:19 PM
charliew   The later angle pull spreaders are to me the best ...   Feb 22 2009, 01:24 PM
Steve   I finally put mine together and tested it out at W...   Jul 29 2009, 06:40 PM
Steve   Here's a picture of the fabbed up cable. You ...   Jul 29 2009, 06:45 PM
Steve   Here's another picture of the copper pipe befo...   Jul 29 2009, 07:14 PM
- Lo-Fi Version Time is now: 18th October 2026 - 03:45 PM
