| Wes V |
Oct 4 2008, 07:07 PM
Member ![]() ![]() Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 |
I think I've come up with a totaly new way to hook up 911 parking brakes. It involves making up longer hybrid cables.
It's not complex, doesn't cost tons, and is about as straight forward as possible. It functions exactly as intended in the 911. Here is a teaser photo; (IMG:http://www.performanceforum.com/wesvann/914a/my-rear-brake/b-mrb1.jpg) Here is a link to my write-up on how I did it (it's a preliminary write-up). hybrid cables Wes (can somebody please find me the photo that I've seen on this site where somebody used a cable end block at the parking brake lever that had set screws) |
| craig downs |
Oct 10 2008, 01:17 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 770 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
Mocking up a shoe stop I'll make them up this weekend. The stop will have to have support blocks welded on to reach the rear of the spreaders.
| Wes V |
Oct 10 2008, 09:50 AM
The stop will have to have support blocks welded on to reach the rear of the spreaders. This comment has me confused!! As I read it, you are saying that there is a "stop" that limits how far to the side the spreader can move. (in addition to rubbing on the "backing plate") I can't see the need due to the fact that the shoe will only move outward a certain amount and that would limit the side to side movement. (as you pull on the cable, it would pull the spreader and shoe assembly off to that side and stop once that shoe is in contact with the drum. Then continuing to pull would spread the other shoe outward) It may have somthing to do with the fact that there will always be a certain amount of tension on the cable?? Maybe I'm just reading your comment wrong!!! If you could add an arrow to the photo showing the wear pattern on the spreader, it may make it clear. That brings up another subject! Are you planning on installing a "return" spring (as shown on that sub-cable)? I haven't seen anybody show consern about it, even in bell-crank versions. In most versions, everybody is counting on the shoe return spring (the one near the spreader) on pulling the cable back!!!!! In the original 911, there isn't an additional return spring, but that's a straight pull. What was there in the original BMW installation?? (wish I had a black E30 to look under!) Wes |
| Richard Casto |
Oct 10 2008, 12:47 PM
Blue Sky Motorsports, LLC ![]() ![]() ![]() Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
The stop will have to have support blocks welded on to reach the rear of the spreaders. This comment has me confused!! Wes, you are a good sport for allowing the thread hijack. (IMG:style_emoticons/default/smile.gif) And Craig stop me if I am way off base here. So, I "think" that what Craig is saying when he says the "rear of the spreaders" is the part that would be next to the backing plate. And that in addition to pushing against the shoes, the spreaders also need to push against something along the other axis to prevent from putting an un-needed side load on the shoes. The image below is without a plate for the spreader to push against. The green arrow is the force from the cable. The red arrows is the force from the spreader on the shoes. So you see in addition to the force that pushes the shoes against the drum, you also have an un-needed side force. ![]() In the image below, the blue is a plate for the spreader to push against. The green arrow is the force from the cable. The red arrows is the force from the spreader on the shoes. The purple arrows is the force from the spreader on the blue plate. So here the only force on the shoes is the ones pushing them against the drum. ![]() Also in the above photos you can see how the two pivot points on the spreader are offset away from what would be the backing plate. So if I understand Craig correctly, I think he is saying that in addition to just bending a flat section of metal 90 degree to create the “stopping block” that he may also need to weld in something extra (what I show in blue above) onto that to take into account that offset. In the image below, you can see the bent "stopping block" but with two extra sections welded on to account for the offset and meet up with the spreader. ![]() |
Wes V A different way to hook up 911 e-brakes Oct 4 2008, 07:07 PM
okieflyr Sweeeeet! :popcorn: Oct 4 2008, 07:55 PM
Wilhelm Nice write up.
What are your ideas for the parki... Oct 4 2008, 09:53 PM
Wilhelm
Nice write up.
What are your ideas for the park... Oct 4 2008, 10:38 PM
LarryR Very nice! I am getting ready to to the 911 br... Oct 4 2008, 10:09 PM
PRS914-6 Nice write up. Most of us have thought of the ide... Oct 4 2008, 11:17 PM
Larry Hubby Clever and resourceful, Wes. Looks good!
Larr... Oct 5 2008, 03:49 AM
PRS914-6 Another thought on your idea........I don't ha... Oct 5 2008, 08:50 AM
Wes V The issue with the bell-crank solution is that it ... Oct 5 2008, 11:27 AM
Wilhelm
The issue with the bell-crank solution is that it... Oct 5 2008, 11:52 AM
Richard Casto
The 928,944, 924 mechanism requires only a pull, ... Oct 6 2008, 12:55 PM
andys
Another thought on your idea........I don't h... Oct 6 2008, 10:57 AM
Wilhelm
[quote name='PRS914-6' post='1087728' date='... Oct 6 2008, 08:25 PM
jj83118 I was going to post my 911 e-brake cable solution,... Oct 5 2008, 03:13 PM
jj83118 Another shot from the inside. Oct 5 2008, 03:16 PM
jj83118 Welded cable end. Oct 5 2008, 03:17 PM
Wilhelm
Welded cable end.
So when you cut this cable e... Oct 5 2008, 04:50 PM
Wes V
Welded cable end.
I like this!
I never th... Oct 5 2008, 06:17 PM
jj83118 A complete cable (still need to shorten the thread... Oct 5 2008, 03:19 PM
sixnotfour
silver solder the way to go but crimping is way m... Oct 5 2008, 04:54 PM
ClayPerrine This thread made me want to post this now. The pr... Oct 5 2008, 07:06 PM
Wes V Clay;
The fact that what I did would place the sh... Oct 5 2008, 08:09 PM
ClayPerrine
Clay;
I'd have prefered that you just post t... Oct 5 2008, 08:42 PM
jj83118 I welded the crimped ends back on with a MIG welde... Oct 5 2008, 09:32 PM
Richard Casto Wes,
Thanks for showing how you did this. I am s... Oct 6 2008, 12:49 PM
Wes V This is what AndyS is talking about when he commen... Oct 6 2008, 01:12 PM
Richard Casto Wes,
Thats pretty cool. Basically its just like ... Oct 6 2008, 01:47 PM
Wes V Richard;
In light of the fact you can figure out ... Oct 6 2008, 02:03 PM
Richard Casto I am an Electrical Engineer by training, but I sti... Oct 6 2008, 03:43 PM
Wes V
If someone wants to send me the 924/944/928 parts... Oct 6 2008, 05:15 PM
ClayPerrine I actually looked at the 924/944 solution. The mou... Oct 6 2008, 09:53 PM
Wilhelm
I actually looked at the 924/944 solution. The mo... Oct 6 2008, 10:37 PM
ClayPerrine
I actually looked at the 924/944 solution. The m... Oct 7 2008, 07:42 AM
Wes V (I'm glad I started this sting)
Here's a ... Oct 7 2008, 11:03 AM
Wes V I think it dawned on me why Clay said that the 944... Oct 7 2008, 11:51 AM
jcd914
I think it dawned on me why Clay said that the 94... Oct 7 2008, 12:56 PM
ClayPerrine 66-68 911 park brakes are the same as the later on... Oct 7 2008, 01:26 PM
Wes V I formally bow in humility to Clay Perrine! :w... Oct 7 2008, 07:09 PM
craig downs I've been working on this also for about two w... Oct 7 2008, 11:55 PM
craig downs Here a little what I've done
You have to remov... Oct 8 2008, 12:05 AM
craig downs and
Oct 8 2008, 12:07 AM
Richard Casto Craig,
Excellent job! It looks like you are ... Oct 8 2008, 02:55 PM
craig downs 911 shoe on the left and a 944 on the right it the... Oct 8 2008, 12:28 AM
Richard Casto
911 shoe on the left and a 944 on the right it th... Oct 8 2008, 03:08 PM
smdubovsky Just about every porsche other than the 911/912 ... Oct 8 2008, 09:39 AM
andys Guys,
Keep up the good work. This thread is getti... Oct 8 2008, 11:12 AM
Richard Casto Just spent a few minutes looking at PET for 924, 9... Oct 8 2008, 02:51 PM
ClayPerrine I have had sitting side by side in front of me a 9... Oct 8 2008, 03:09 PM
craig downs I'm totally aware of how the backing plate is ... Oct 8 2008, 09:04 PM
Wes V Craig;
On the prior page, jcd914 posted a photo s... Oct 9 2008, 09:31 AM
Wes V Craig;
Here is some more "food for thought... Oct 9 2008, 12:51 PM
ClayPerrine In the middle of the day today a stray thought abo... Oct 9 2008, 02:05 PM
Eric_Shea
Not sure if that's accurate. I believe they... Oct 9 2008, 02:28 PM
ClayPerrine
Not sure if that's accurate. I believe the... Oct 9 2008, 03:09 PM
Eric_Shea Wait... rethinking. You're right.
The spreade... Oct 9 2008, 02:34 PM
ClayPerrine
The spread... Oct 9 2008, 03:11 PM
Richard Casto I think another way to say what Eric is saying is.... Oct 9 2008, 03:16 PM
Wes V I agree with what Richard is saying.
Think of the... Oct 9 2008, 03:40 PM
smdubovsky
If you yank on the parking brake while the car is... Oct 9 2008, 03:52 PM
PRS914-6 Guys, you have to have a firm stop and the shoes h... Oct 9 2008, 03:58 PM
Eric_Shea I almost had it :lol3:
The "stop" preve... Oct 9 2008, 06:49 PM
craig downs Lots of good information this is a fun thread and ... Oct 10 2008, 12:53 AM
Wes V
Lots of good information this is a fun thread and... Oct 10 2008, 09:02 AM
craig downs Checking cable line up. Going to cut and realign c... Oct 10 2008, 01:00 AM
craig downs In the relaxed position
In the pulled positio... Oct 10 2008, 01:09 AM
Richard Casto
Mocking up a shoe stop I'll make them up this... Oct 10 2008, 12:50 PM
craig downs This show why the spreaders need rear support as y... Oct 10 2008, 01:22 AM
Wes V Craig;
Here is an idea for you to think about;
M... Oct 10 2008, 09:23 AM
Phoenix-MN "Are you planning on installing a "retur... Oct 10 2008, 09:57 AM
Richard Casto Continuing to think out loud here. I promise this... Oct 10 2008, 01:01 PM
Wes V Richard;
I think your "drawn" diagram i... Oct 10 2008, 01:27 PM
smdubovsky Heres a pic of an early steel 911 arm. The late a... Oct 10 2008, 04:05 PM
craig downs Richard figured it out what I was trying to explai... Oct 10 2008, 07:04 PM
Steve I would love to do this to my car. Does anyone kn... Jan 3 2009, 12:23 PM
burton73 Steve,
You are still going to need a set of rear ... Jan 3 2009, 06:36 PM
Steve
Steve,
You are still going to need a set of rear... Jan 4 2009, 07:57 PM
charliew It looks to me that the aluminum arm style straigh... Jan 4 2009, 05:27 PM
charliew I bought some 911 rear brakes and aluminum arms on... Jan 5 2009, 11:34 AM
Steve I bought these parts from Parts Heaven. They do n... Feb 21 2009, 11:13 PM
Steve Here's the one with the bolt holes. Feb 21 2009, 11:14 PM
craig downs You happen to get a later year e-bake assembly tha... Feb 22 2009, 01:42 AM
Steve
You happen to get a later year e-bake assembly th... Feb 23 2009, 09:03 AM
jaxdream Hi guys , I too have been wanting a 911 ebrake set... Feb 22 2009, 11:34 AM
PRS914-6 Actually, if you have good cables the two springs ... Feb 22 2009, 12:06 PM
scotty b I think I still have a complete 86 944 rear suspen... Feb 22 2009, 12:19 PM
charliew The later angle pull spreaders are to me the best ... Feb 22 2009, 01:24 PM
Steve I finally put mine together and tested it out at W... Jul 29 2009, 06:40 PM
Steve Here's a picture of the fabbed up cable. You ... Jul 29 2009, 06:45 PM
Steve Here's another picture of the copper pipe befo... Jul 29 2009, 07:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th October 2026 - 03:45 PM |
