| Doug Leggins |
Oct 11 2008, 08:48 PM
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None
This one has me puzzled. My car runs absolutely great most of the time. Has good drivability around town in stop and go traffic. Is a freakin blast in 3rd gear at 4500 – 5000 RPM though the twistys. It normally runs just like it should in any gear at any RPM. But... it has developed this nasty habit of cutting out at random times. It first occurred back in July when I was driving to the Porsches to Oxford event. I left my house and had been driving along for around 25 minutes, I was cruising along at about 50 miles an hour and it cut out and sounded like it was running on 1 or 2 cylinders. I pulled into a lot and feathered the throttle. It sputtered for 5 seconds or so and then started running fine, just like it should run. I shut the car off and it started right back up like nothing had happened. I got back on the road to Oxford. About one and a half hours later it did it again. This time I was driving around at about 30 mph. It sputtered, kept running poorly for about 5 seconds (again sounding like it was running on 1 or 2 cylinders). I feathered the throttle a few times and it came right out of it and started running fine.
This type of cutting out is still randomly occurring. It will sputter for 5 seconds or so and then come out of it. Or, sometimes the feathering of the throttle will not bring it out of the sputtering and it will die or I will shut it off. It will usually start back up after cranking on the starter for 6-8 seconds (That kind of cranking that seems like winding the car up and eventually it builds up enough desire that it starts.) Usually it starts up and sounds like its running on 1-2 cylinders. After this type of “wind it up” starting 2 or 3 times, it will start up and be running just fine. Then back on the road.... I haven’t been able to determine any pattern other than it will continue to happen until I fix something. The details of what I am working with: 2056 built by Jake some years back, dual Weber 40’s, Mallory Uni-Lite distributor, Facet Fuel pump, MSD 6AL. Here’s what I’ve done so far: replaced the fuel filter, installed new facet fuel pump, installed new Aurora plug wires ( I had them and thought maybe it would help), sync’d the carbs. I bought carb rebuild kits but haven’t rebuilt the carbs yet. Thought I’d check with you all for other ideas before I rebuilt the carbs. Any ideas on what could be causing the cutting out? Oh yea, one more thing that occurred 2 times tonight while test driving. The car backfired out of the exhaust 3-4 times in rapid succession in about a second or two. Then the car ran just fine after that. I sure could use some help on this one. I can’t drive it like this to the Rocket City Ramble. |
| ArtechnikA |
Oct 12 2008, 06:13 AM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
This type of cutting out is still randomly occurring. It will sputter for 5 seconds or so and then come out of it.... ... MSD 6AL. It is widely if not well-known that I dislike the MSD-6 for exactly this reason. I fought this problem for a year before finally replacing the "surely it can't be that' (and most expensive) part. If you don't have the high-vibration Blaster-2 pulse transformer ("coil") it couldn't hurt to throw one of those at the problem. But having a known-good real coil and condenser available as a backup could be a good thing to have in your spares kit. |
Doug Leggins Car cutting out, Now FIXED -thanks! Oct 11 2008, 08:48 PM
Garold Shaffer Head temp sensor? My B-inlaw had a some what simul... Oct 11 2008, 10:33 PM
toon1 sounds like an intermitint elec short.
These ca... Oct 11 2008, 10:43 PM
dbgriffith75 :agree:
It could be a wiring/grounding issue. Bu... Oct 11 2008, 11:05 PM
ejm Replace the coil Oct 11 2008, 11:07 PM
Doug Leggins Great input so far guys. I'll try some of thes... Oct 11 2008, 11:58 PM
cooltimes Fuel. If it started happening suddenly, I would th... Oct 12 2008, 12:48 AM
ClayPerrine Doug,
Just bring it to the RCR. Or just come to... Oct 12 2008, 08:12 AM
Doug Leggins I swapped out the coil. It did have a Pertronix Fl... Oct 12 2008, 12:50 PM
Doug Leggins MSD disconnected and went for a test drive. Drove ... Oct 12 2008, 04:58 PM
Mike914
MSD disconnected and went for a test drive. Drove... Oct 12 2008, 06:46 PM
ClayPerrine
MSD disconnected and went for a test drive. Drove... Oct 12 2008, 07:25 PM
tommy914
MSD disconnected and went for a test drive. Drove... Oct 12 2008, 09:19 PM
Doug Leggins Changed back to the 130 main jets and drove to din... Oct 12 2008, 09:06 PM
ClayPerrine
Clay - It would be great to join up with the cara... Oct 12 2008, 09:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 11:28 AM |
