> Valve adjustment on a 914-6, Pictures please
John
post Aug 25 2008, 08:14 PM
member? what's a member?
Does anyone have any photo evidence that it is possible to remove the lower valve covers (to do a valve adjustment) with the 6-cyl engine in the car?
I have heard rumors that it is possible to do without removing the engine, and I do not believe that the covers will clear the lower studs and the suspension console without lowering the engine (which I do not want to do).
I'll attempt it, if some kind folks will post some pictures of how to get the lower valve covers off.
For those of you who don't know, I am in process of moving away from my shop and am temporarily in an apartment. I moved the car over here, but it is in need of a valve adjustment and all I have is an apartment size garage and almost no tools. There is a Harbor Freight store in town where I may get some temporary tools to get the job done, or I may bring some tools back with me on my next trip home. (very likely to happen)
On second thought, I could probably get the car high enough to pull the motor and do a proper job here in the apartment garage. I just need my tools............
For those who care, I am moving from Kansas City to Evansville, IN.
I would still like to see some pictures (of removing the lower valve covers) if anyone has any.
P.S. the engine is a 1984 3.2
Downunderman
post Oct 12 2008, 02:02 PM
Region Association: Australia and New Zealand
I got rid of the studs and replaced them with flange headed bolts. Lower cover doesn't need grinding then. Use the back side method as per Waynes tech article. It's foolproof.
John   Valve adjustment on a 914-6   Aug 25 2008, 08:14 PM
mikez   IF you have turbo valve covers and someone was nic...   Aug 25 2008, 08:42 PM
John   I'm almost afraid to ask. WTF does GTTTTPI me...   Aug 25 2008, 09:09 PM
mikez   Got The Teeshirt To Prove It.... Oopsie, one to m...   Aug 25 2008, 09:15 PM
Phoenix 914-6GT   oops.... don't know how this one posted withou...   Aug 25 2008, 09:16 PM
Phoenix 914-6GT   It is easy to do but Mike is right. If you have th...   Aug 25 2008, 09:17 PM
effutuo101   what picture Jon? I have an apartment sized garage...   Aug 25 2008, 09:18 PM
John   what picture Jon? I have an apartment sized garag...   Aug 25 2008, 09:38 PM
effutuo101   There they are! :)   Aug 25 2008, 09:19 PM
Phoenix 914-6GT   Here is one from my engine when I had it out. You ...   Aug 25 2008, 09:30 PM
Phoenix 914-6GT   No, you will need to take different amounts off ea...   Aug 25 2008, 09:50 PM
John   No, you will need to take different amounts off e...   Aug 25 2008, 10:46 PM
Phoenix 914-6GT   Well, they are kinda in the way but it is just a m...   Aug 25 2008, 10:57 PM
9146986   I take of the heat exchangers on a car that's ...   Aug 26 2008, 07:46 AM
morgan_harwell   I loosen the front motor mounts, then lift the eng...   Aug 26 2008, 12:19 PM
FourBlades   Heaven must look like this. :drooley: :drooley:...   Aug 26 2008, 12:48 PM
Eddie914   Isn't it easier to "just" pull the e...   Aug 26 2008, 02:04 PM
morgan_harwell   Isn't it easier to "just" pull the ...   Aug 26 2008, 02:24 PM
iamchappy   I've adjusted the valves in the car and have d...   Aug 26 2008, 02:28 PM
John   I've adjusted the valves in the car and have ...   Aug 28 2008, 12:14 AM
PRS914-6   Thank You! You guys reminded me why I was so i...   Aug 28 2008, 09:21 AM
John   Last weekend I did get my valve covers off and adj...   Oct 8 2008, 11:13 PM
scotty   There's not nearly enough oil in those picture...   Oct 8 2008, 11:35 PM
Phoenix 914-6GT   There's not nearly enough oil in those pictur...   Oct 9 2008, 12:53 AM
John   I removed material from the lower valve covers and...   Oct 11 2008, 04:54 PM
Phoenix 914-6GT   :headbanger: nice work. Now go find that garage of...   Oct 11 2008, 05:11 PM
DownUnderMan   I got rid of the studs and replaced them with flan...   Oct 12 2008, 02:02 PM
- Lo-Fi Version Time is now: 30th April 2026 - 05:28 AM
