Pedal Cluster Brake Switch |
7TPorsh |
Oct 23 2008, 12:09 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Well i traced my faulty brake lights to a bad cluster switch; i think. I bridge the two wires and I get light, but on switch no light.
Going to take it out and try to clean it. My question: Will the switch work if it is not mounted? ..hold in my hand and pull on lever...should it work in my hand? or it has to be mounted/grounded? thx |
ArtechnikA |
Oct 23 2008, 12:34 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
southernmost914 |
Oct 23 2008, 12:54 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
My question: Will the switch work if it is not mounted? yes. two wires - one hot, one ground. it does not ground through the case. Two wires -One positive ,one load, switch is spring loaded and normaly closed ( unmounted lit) Steve |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:40 AM |
