> Heat exchangers for a six, Who makes the best?
Johny Blackstain
post Oct 27 2008, 09:23 AM
I'm not 18 anymore & require heat in my car. I bought my six off the 914world classifieds 2 yrs ago & have found the car to be a blast, except in the winter. Very good for the air cooled engine, very bad for my bones. Obviously I have headers & I love the power, torque & sound I get out of them. I'd like to presume that the original heat exchangers were removed for the number 1 reason here on the East Coast... RUST & $COST$. I can live w/out A/C, but heat is a must. Suggestions? The six is sporting a high compression 2.7.
IronHillRestorations
post Oct 27 2008, 11:31 AM
I. I. R. C.
B&B makes some, but 3 out of 4 sets won't fit right. Unless you like to deal with returns/rework/return shipping, I'd try another brand.
GHL makes some, but I haven't seen those first hand. They will be the next I try if I do another car with a big engine that needs heat.
The factory heat exchangers work very well for engines up to, and including a 3.0. They have excellent flow. You might give up a little power on the top end, but not much. The much storied 215hp carb'd 3.0 in Bruce Anderson's book, was in fact in a 914-6 with factory heat exchangers.
It's very rare to find a set that doesn't need some repair to the heat shells. The exhaust pipes are close to the shells at the bottom which oxidizes the metal and helps it rust. For the most service life I recommend doing whatever repairs are needed and then getting them Jet-Hot coated.
It's also fairly common for the pipe to rust rear of the 3/1 merge. Years ago I built a set of jigs to repair this part for the left and right 6 heat exchangers.
Here's the GHL link: http://www.ghlmotorsports.com/Merchant2/me...gory_Code=PH-NT
B&B: http://www.bbexhaust.com/car/9689146/
Johny Blackstain   Heat exchangers for a six   Oct 27 2008, 09:23 AM
type47   i think there are some stainless steel HE (w/heat)...   Oct 27 2008, 09:58 AM
Johny Blackstain   i think there are some stainless steel HE (w/heat...   Oct 27 2008, 10:08 AM
r_towle   i think there are some stainless steel HE (w/hea...   Oct 27 2008, 10:29 AM
Johny Blackstain   Have you checked with SSI? I think they are still...   Oct 27 2008, 10:32 AM
r_towle   [quote name='r_towle' post='1095341' date='Oct 27...   Oct 27 2008, 10:39 AM
Johny Blackstain   have you heard of Google...? Its a really simple ...   Oct 27 2008, 10:50 AM
jd74914   Why would that be? The stock /6 ones were made for...   Oct 27 2008, 10:18 AM
Johny Blackstain   Why would that be? The stock /6 ones were made fo...   Oct 27 2008, 10:29 AM
J P Stein   No SSIs for a 914/6. From what I have heard, the ...   Oct 27 2008, 11:01 AM
GeorgeRud   Unless something has changed, SSI has never made a...   Oct 27 2008, 11:03 AM
SirAndy   Unless something has changed, SSI has never made ...   Oct 27 2008, 04:25 PM
SirAndy   The other option is to install an Eberspacher gas...   Oct 27 2008, 04:27 PM
9146986   B&B makes some, but 3 out of 4 sets won't ...   Oct 27 2008, 11:31 AM
Johny Blackstain   B&B makes some, but 3 out of 4 sets won't...   Oct 27 2008, 12:39 PM
9146986   Here's a pic from the GHL website, the heater ...   Oct 27 2008, 11:49 AM
J P Stein   Here's a pic from the GHL website, the heater...   Oct 27 2008, 12:07 PM
dr914@autoatlanta.com   Here's a pic from the GHL website, the heate...   Feb 8 2010, 04:31 PM
Lavanaut   With that stated who of us would pay 3500.00 for a...   Feb 8 2010, 05:48 PM
dr914@autoatlanta.com   With that stated who of us would pay 3500.00 for ...   Feb 9 2010, 04:15 PM
number6   With that stated who of us would pay 3500.00 for ...   Feb 8 2010, 09:32 PM
dr914@autoatlanta.com   I will try to get and post a picture of the stainl...   Feb 9 2010, 04:19 PM
Lavanaut   The original factory ones are available, though t...   Oct 27 2008, 12:53 PM
Johny Blackstain   I don't think this is true. George @ AA told...   Oct 27 2008, 01:00 PM
Lavanaut   [quote name='Lavanaut' post='1095386' date='Oct 2...   Oct 27 2008, 01:06 PM
Johny Blackstain   What I was getting at is that, as others have alr...   Oct 27 2008, 01:17 PM
number6   [quote name='Lavanaut' post='1095391' date='Oct 2...   Oct 27 2008, 05:10 PM
Johny Blackstain   The Patrick Motorsports is the Billy Boat. There...   Oct 27 2008, 05:34 PM
number6   The Patrick Motorsports is the Billy Boat. There...   Oct 27 2008, 05:43 PM
PanelBilly   I'm not far enough into my car build to be loo...   Oct 27 2008, 01:08 PM
GeorgeRud   The difficulty is that you should not weld the out...   Oct 27 2008, 01:19 PM
Johny Blackstain   "Luftecnic", SSI distributors here on th...   Oct 27 2008, 01:39 PM
iamchappy   Or the Hayword and Scott. Which might be a pain to...   Oct 27 2008, 02:45 PM
Johny Blackstain   Or the Hayword and Scott. Which might be a pain t...   Oct 27 2008, 03:30 PM
number6   I have the stock HE's but have found that the...   Oct 28 2008, 05:03 PM
morgan_harwell   I'm looking forward to an actual owner/user of...   Oct 27 2008, 04:09 PM
Root_Werks   I'm looking forward to an actual owner/user o...   Oct 28 2008, 12:42 PM
iamchappy   Johny, if you contact them ask if they can make th...   Oct 27 2008, 05:52 PM
Johny Blackstain   Johny, if you contact them ask if they can make t...   Oct 27 2008, 06:07 PM
number6   Johny, if you contact them ask if they can make ...   Oct 27 2008, 08:24 PM
Johny Blackstain   I shot them an email as well. Will share any info...   Oct 27 2008, 08:29 PM
number6   I did not ask about a larger diameter yet & y...   Oct 28 2008, 04:33 AM
9146986   The Hayward & Scott have welds inside the heat...   Oct 27 2008, 11:41 PM
number6   The Hayward & Scott have welds inside the hea...   Oct 28 2008, 04:29 AM
SirAndy   The Hayward & Scott have welds inside the he...   Oct 28 2008, 12:52 PM
Root_Werks   There is a special wrench you can buy for VW/Porsc...   Oct 28 2008, 01:51 PM
Phoenix 914-6GT   It looks like they use the same headers as Triad w...   Oct 28 2008, 02:01 PM
9146986   These came up in a thread about a year ago, and I ...   Oct 28 2008, 02:22 PM
iamchappy   I would think a few well placed holes drilled into...   Oct 28 2008, 02:27 PM
number6   A follow-up response: Yes we can make them in whi...   Oct 28 2008, 03:01 PM
Eric_Shea   Andy, Whay I think Perry is referring to is havin...   Oct 28 2008, 03:29 PM
Lavanaut   If there is a weld that is contained within that ...   Oct 28 2008, 04:59 PM
Root_Werks   If there is a weld that is contained within that...   Oct 28 2008, 05:03 PM
iamchappy   Stock HE's will work with the 3.2 ok, i know t...   Oct 28 2008, 05:16 PM
number6   From Hayward & Scott, in response to my inquir...   Oct 29 2008, 03:47 AM
Eric_Shea   If anything is wrong or goes wrong with that wel...   Oct 29 2008, 08:29 AM
luisqcosta   you can always try the source for these exhausts...   Oct 29 2008, 06:35 PM
morgan_harwell   Does anyone here use the GHLs? The heaterboxes on ...   Oct 30 2008, 08:02 AM
Dr Evil   Hey Al, come April at the Hershey swap meet you ca...   Oct 30 2008, 03:53 PM
jim912928   I purchased the GHL's however I don't know...   Oct 30 2008, 05:26 PM
Johny Blackstain   :popcorn: What a thread! I just got back la...   Oct 31 2008, 11:47 AM
amallagh   Johnny et al, did you end up buying a set of excha...   Dec 1 2008, 07:11 PM
Johny Blackstain   Johnny et al, did you end up buying a set of exch...   Dec 1 2008, 08:08 PM
number6   Johnny et al, did you end up buying a set of exch...   Dec 1 2008, 10:01 PM
TedK   Their website says 1500 pounds before shipping, ho...   Dec 1 2008, 09:25 PM
amallagh   Their website says 1500 pounds before shipping, h...   Dec 2 2008, 02:55 AM
GeorgeRud   A good carbon monixide detector (used in small air...   Dec 1 2008, 10:08 PM
Johny Blackstain   £1305.00 is the price Ian quoted me, including sh...   Dec 4 2008, 03:14 PM
Eric_Shea   "Any" time you have welds hidden under...   Dec 4 2008, 04:34 PM
thesey914   I like the Eberspacher Idea. Cheaper than exchange...   Dec 8 2008, 02:37 AM
Johny Blackstain   Well, the Hayward & Scott exchangers are on th...   Dec 20 2008, 10:44 AM
number6   Well, the Hayward & Scott exchangers are on t...   Dec 20 2008, 06:16 PM
Johny Blackstain   In writing w/ Ian the price I was quoted was less ...   Dec 24 2008, 06:42 PM
number6   In writing w/ Ian the price I was quoted was less...   Dec 24 2008, 07:15 PM
Johny Blackstain   Al, when will those puppies go on? -duc I have t...   Dec 24 2008, 07:53 PM
number6   Al, when will those puppies go on? -duc I have ...   Dec 24 2008, 08:09 PM
LarryR   In writing w/ Ian the price I was quoted was less...   Dec 25 2008, 12:49 AM
Johny Blackstain   Has anyone got a part number for the rubber gasket...   Dec 24 2008, 09:48 PM
9146986   6's don't have that, and they don't ha...   Dec 24 2008, 10:56 PM
Johny Blackstain   6's don't have that, and they don't h...   Dec 25 2008, 09:32 AM
9146986   Al, only the 4's have that grommet. The pape...   Dec 25 2008, 10:09 AM
Johny Blackstain   Seems wanting some heat in my car is nickle & ...   Jan 13 2009, 09:55 AM
6freak   Seems wanting some heat in my car is nickle ...   Jan 13 2009, 01:40 PM
PanelBilly   Come on now, get this done so we'll know if it...   Jan 13 2009, 10:57 AM
9146986   What I did on one conversion car was put the flapp...   Jan 13 2009, 06:43 PM
morgan_harwell   :bump: >[Johny Blackstain, early 2009-ish]. ...   Feb 8 2010, 01:07 PM
Eric_Shea   Great timing... I think Al's got about 3' ...   Feb 8 2010, 02:25 PM
PanelBilly   not I and I'm one known to waste money on such...   Feb 8 2010, 04:51 PM
Johny Blackstain   My lazy ass still has not put them in yet so I don...   Feb 9 2010, 07:38 AM
amallagh   I bought a set of the H&S heat exchangers in D...   Feb 9 2010, 03:17 PM
dr914@autoatlanta.com   Here is a picture of the four cylinder heat exchan...   Feb 9 2010, 05:00 PM
- Lo-Fi Version Time is now: 7th November 2026 - 06:23 AM
