| Wes V |
Nov 3 2008, 12:01 PM
Member ![]() ![]() Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 |
I'm rebuilding a set of rear "M" calipers for my 914 and have a bunch of questions.
1. Inside the bore of the caliper there is a pin that goes into a mechanism within the piston. What the heck is it for? How do I remove it? Is it screwed into the caliper body or just press fitted into place. It needs to be removed in order to hone the bore. 2. If I can get rid of the "pin" within the bore of the caliper, what pistons can I use. I know it's easy to remove the mechanism within the piston (simple snap ring), but I have to get new pistons anyway. An actual porsche part number would be nice!! (Stoddard lists some aftermarket 38mm stainless steel pistons, but I'm not sure if they are applicable or have the stepped to surface talked about in the next point) 3. The pistons have to be installed (rotated) as shown in the following diagram. (IMG:http://www.performanceforum.com/wesvann/914a/piston-angle.jpg) This places the lower "stepped" surface of the piston in the upper position. It's not due to the pad having an "index'd" matching surface (the pad just has a flat surface), and as such I've got to ask why it matters? (I have to assume it's so that the initial "bite" of the pad is lessened on the leading edge) 4. Are any of the "rebuild" kits better than others. (the kit normally is just the piston o-ring, dust seal, and retainer clip) Are there any to avoid? 5. The four bolts that hold the calipers together are 7mm (from the factory) and when loose, the parts of the caliper sure sure do flop around a lot!! Has anybody used 8mm bolts to help alignment and also be stronger. Where would you get 8mm bolts in the correct grade (12.9?). If you just use the factory 7mm bolts, are there any secrets to keeping everything aligned while tightening. (since I'm talking about the bolts, what should they be torqued too?) Other than the factory, is there a good source for the bolts? 6. Any idea on cost of zinc plating? (the parts have been blasted and clean) Wes Vann |
| Cap'n Krusty |
Nov 3 2008, 12:57 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
The correct kit is difficult to come by. You're dealing with the parking brake mechanism inside the piston. You need a kit with the appropriate seals for the parking brake portion of the caliper and the o-rings between the caliper halves. I've not heard of replacing the bolts. Eric Shea at PMB Performance rebuilds these calipers and does a great job at a fair price. He probably would be a good source for the parts.
The Cap'n |
Wes V questions about "M" calipers Nov 3 2008, 12:01 PM
Wes V
You're dealing with the parking brake mechan... Nov 3 2008, 01:06 PM
Cap'n Krusty
You're dealing with the parking brake mecha... Nov 3 2008, 01:51 PM
Wes V Cone; I agree that Eric does a great job and his p... Nov 3 2008, 01:59 PM
ConeDodger Put them in a box. Send them to PMB with a check f... Nov 3 2008, 01:23 PM
Eric_Shea You ask a lot of questions... :D
1. Knock-Back me... Nov 3 2008, 04:35 PM
Wes V Eric; (without a "K")
Thanks!
(Ya,... Nov 3 2008, 05:12 PM
DBCooper
(Ya, I tend to ask a whole bunch of questions, bu... Nov 3 2008, 06:49 PM
Eric_Shea At twice the price I'll buy the Ribe Bit set a... Nov 3 2008, 07:06 PM
Wes V One thing I've noticed when doing searches on ... Nov 3 2008, 07:39 PM
Eric_Shea PM your credit card info for the answer... :P Nov 3 2008, 09:21 PM
DBCooper
... Nov 3 2008, 09:30 PM
sixnotfour
Just dive in, if the bolts are factrory they are ... Nov 3 2008, 09:29 PM
Eric_Shea Alright... I feel sorry for ya. Here's my 5 m... Nov 3 2008, 09:33 PM
davep Just like Eric, I've been rebuilding calipers ... Nov 4 2008, 09:07 AM
Wes V OK, bolts are an issue.
901.352.978.12 is NLA.
S... Nov 4 2008, 06:03 PM
Eric_Shea It's your life.
I would NEVER do that as 1/... Nov 4 2008, 06:18 PM
Wes V I measured the shank on the original Ribe bolt and... Nov 4 2008, 07:04 PM
andys
I measured the shank on the original Ribe bolt an... Nov 5 2008, 01:14 PM
Wes V This whole thing got started when I was just putti... Nov 5 2008, 05:33 PM
Eric_Shea You asked questions. I gave you the answers.
I wo... Nov 5 2008, 06:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:58 PM |
