> Rust Inhibitors
Zeke
post Jan 15 2004, 11:57 PM
Never left, but not right....
You guys are pretty tough, especially when I come up with an idea. But I have been pursuing information on a process of rust protection and arrest for inaccessable areas like the rockers, doors, lower rear portions of the front fenders and rear edge of rear deck lid. Things like that. Not to mention the whole 914!
I know there are fleet applications for the military and the likes of UPS. I have found a few candidates for the job. One is sold under the name Carwell Rust Cop.
Another is a cosmoline based product that hardens and seals. Has a fantastic life span as opposed to the Rust Cop which must be renewed periodically. (And that makes marketing sense beacuse Carwell is really in the application business so why would they feature a one time process when they can come back time and again?)
A third is a lanolin base that can be used safely around the interior and taillight housings where it might get on the paint. The cosmoline formula is tough to remove once on.
There is even another 'Vaseline,' or petolatum, based one for a lighter more temporary use in the shop.
Comments? Anyone have any additional info for this type of thing? Seems like with our older cars, we would need as much rust protection as we can get.
__________________
McMark
post Jan 16 2004, 01:18 PM
914 Freak!
Painting the whole car in POR-15 is a great option, but still has the problem of only covering the areas you can see. Those surfaces aren't really a problem, for the most part. If I could dip in POR-15 then we might be on to something.
Zeke   Rust Inhibitors   Jan 15 2004, 11:57 PM
Zeke   Stopping rust once it's there is dicey w/o tot...   Jan 16 2004, 12:00 AM
McMark   Along these lines, I'm curious about whole car...   Jan 16 2004, 12:14 AM
steve@ottosvenice.com   I melt wax in acetone.,then spray it with my hudso...   Jan 16 2004, 12:16 AM
SirAndy   <...   Jan 16 2004, 12:37 AM
Howard   ok, this is too cheap and too easy, but I have had...   Jan 16 2004, 03:02 AM
RON S.   When I had to redo all the flooring,inner & outer ...   Jan 16 2004, 08:24 AM
redshift   Iron oxide? IT BECOMES RUST!? ;) It becomes ...   Jan 16 2004, 08:39 AM
gklinger   ...   Jan 16 2004, 09:44 AM
Britain Smith   This guy over on the Pelican board sprayed the ent...   Jan 16 2004, 11:20 AM
Zeke   ...   Jan 16 2004, 11:40 AM
rhilgers   http://www.eastwoodco.com/RustvsPOR.asp Carefull ...   Jan 16 2004, 01:18 PM
McMark   Painting the whole car in POR-15 is a great option...   Jan 16 2004, 01:18 PM
kwales   Um, Someplace I've got one of those Brit car ...   Jan 16 2004, 04:50 PM
orthobiz   Apparently Waxoyl no longer available especially i...   Mar 15 2007, 08:37 PM
Bartlett 914   Apparently Waxoyl no longer available especially ...   Mar 18 2007, 07:57 AM
orthobiz   Thanks for answering. I'm getting a 74 1.8 in ...   Mar 18 2007, 08:24 AM
rfuerst911sc   Apparently Waxoyl no longer available especially ...   Mar 19 2007, 05:55 PM
Bartlett 914   I think you are correct about the smell. I am i...   Mar 19 2007, 08:14 PM
sean_v8_914   FePO4 vs FeO or Fe2O3 or...rust OSPHO or JASCO and...   Mar 18 2007, 01:37 AM
914efi   Used oil works well. Messy and should be redone ev...   Mar 18 2007, 08:24 AM
SGB   arizona is a good rust preventative....   Mar 18 2007, 09:46 AM
sww914   Wurth sells a good body cavity wax, 3m has one als...   Mar 19 2007, 08:28 PM
- Lo-Fi Version Time is now: 1st August 2025 - 05:26 AM
