Engine/Tranny Swap, Making Preparations |
mojorisen914 |
Nov 9 2008, 09:45 AM
Visit your local strip club Group: Members Posts: 695 Joined: 9-July 06 From: Denver Colorado Member No.: 6,403 Region Association: Rocky Mountains |
Trying to gather everything I will need to work on my car when I come back to the states for my vacation in December. If my car was back in Kentucky; I wouldn't be asking the following questions since I have the keys to my buddy's shop that is equipped with the lift and all the other necessary tools. BUT, my car is in Kansas at my girlfriends house and I will be swapping out the rebuilt motor/tranny at home in our garage.
I suspect a tranny jack will be the best suited tool to swap out motor and tranny but what does everyone suggest? I'm having to buy jack stands, parts cleaner tank and some other shop equipment that I don't have access to. The jack stands I was looking at have a total height of 24"; add a 2 x 4 on top of the jackstand and I'll get somewhere around 26"s. Is this going to be high enough to swap out the motor and trans? I've done this before but that was 24 years ago and I was helping my uncle swap out his motor in a gravel driveway. Basically what I remember from that is it wasn't any fun. So, any suggestions on swapping out the motor/trans, any special tools needed will be greatly appreciated. Hopefully the time I spend at home working on the car won't turn out like a (IMG:style_emoticons/default/sheeplove.gif) |
mojorisen914 |
Nov 9 2008, 10:07 AM
You should be OK with the jack stands, but you must look at the height of the jack you're going to use, plus the height of the engine. If you need a bit more clearance, removing the rear valance and keeping the front end of the car on the ground will gain you a bit more clearance. I've always used a floor jack, but there was also a write up where someone had used threaded rod in place of the front crossbar bolts, and simply let the front end of the engine down by unthreading the bolts down the rod. I think this would probably be a good way to guide the engine back into the car. That sounds like a good idea with the all thread rod providing the whole thing didn't get in a bind and snap the rod. Something for me to think about and aninexpensive idea...I really like those. THanks. |
Lo-Fi Version | Time is now: 1st June 2024 - 11:59 PM |
