What Fuel pump.., Any vendors? |
ONTHEGRIND |
Nov 20 2008, 06:12 PM
Member Group: Members Posts: 286 Joined: 10-November 08 From: California Member No.: 9,738 Region Association: None |
I have read a little about the MSD pump. I have an account with them but I figured I'd ask before I but.. Car is a 1.7 FI i want a pump that can grow with the new engine setup.. I guess my old pump took a crap car just cranks no fuel pump is kicking on I think it time for a new one..
r_towle |
Nov 20 2008, 06:20 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
first check the fuel pump relay and fuse in the relay box behind the driver in the engine bay...that is typically the culprit.
If you need a replacement for stock is three ports and its a bosch part. If you choose to use the 75/75 two port pump you can choose from several manufacturers. Bosch, Delco, and a few others. It needs to pump (from memory) 65 PSI peak and I forget the GPH.... If you go to a decent parts store you will be able to look in the parts book at the specs of the bosch fuel pump and match those... Rich |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:57 PM |
