What Fuel pump.., Any vendors? |
ONTHEGRIND |
Nov 20 2008, 06:12 PM
Member Group: Members Posts: 286 Joined: 10-November 08 From: California Member No.: 9,738 Region Association: None |
I have read a little about the MSD pump. I have an account with them but I figured I'd ask before I but.. Car is a 1.7 FI i want a pump that can grow with the new engine setup.. I guess my old pump took a crap car just cranks no fuel pump is kicking on I think it time for a new one..
ONTHEGRIND |
Nov 21 2008, 08:55 PM
All the fuses are good..
I kinda have a new question I just got a get of delltoro carbs.. They are 45's though which are probably a little bit big for a stock 1971 1.7 I plan on slapping them on with a new set of heads that I am gonna be doing next week.. I just went to HPH in Redwood city and got a new fuel pump which is stock replacement will this pump not work with the carbs or should I see if I can exchange it for a carb pump.. I also plan to wire in a manual fuel pump switch with what ever pump I may use.. Thanks Dave |
Ericv1 |
Nov 21 2008, 10:34 PM
Member Group: Members Posts: 259 Joined: 30-December 07 From: Cincinnati, Ohio Member No.: 8,518 Region Association: Upper MidWest |
All the fuses are good.. I kinda have a new question I just got a get of delltoro carbs.. They are 45's though which are probably a little bit big for a stock 1971 1.7 I plan on slapping them on with a new set of heads that I am gonna be doing next week.. I just went to HPH in Redwood city and got a new fuel pump which is stock replacement will this pump not work with the carbs or should I see if I can exchange it for a carb pump.. I also plan to wire in a manual fuel pump switch with what ever pump I may use.. Thanks Dave A stock pump for fuel injection is too much pressure for carbs. You'll definately flood the engine and then some. You need a fuel pump for carbs that generates about 4-5psi. |
ONTHEGRIND |
Nov 21 2008, 11:27 PM
All the fuses are good.. I kinda have a new question I just got a get of delltoro carbs.. They are 45's though which are probably a little bit big for a stock 1971 1.7 I plan on slapping them on with a new set of heads that I am gonna be doing next week.. I just went to HPH in Redwood city and got a new fuel pump which is stock replacement will this pump not work with the carbs or should I see if I can exchange it for a carb pump.. I also plan to wire in a manual fuel pump switch with what ever pump I may use.. Thanks Dave A stock pump for fuel injection is too much pressure for carbs. You'll definately flood the engine and then some. You need a fuel pump for carbs that generates about 4-5psi. Good to know I am gonna get the brand new stock pump in tommarow get her running and order the cb fuel pump.. Next week the carbs and heads will go on I may be able to toss in a set of elgins bump sticks in. I will have a write up on the cylinder head/carb and manifold porting and coating... I like to play with the grinder Some pics of my other project.. (IMG:http://img.photobucket.com/albums/v236/xr8ted/100_1285.jpg) (IMG:http://img.photobucket.com/albums/v236/xr8ted/100_1132.jpg) |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:53 PM |
