weber/Del Lorto carbs.., Install guide anywhere |
ONTHEGRIND |
Nov 21 2008, 05:45 PM
Member Group: Members Posts: 286 Joined: 10-November 08 From: California Member No.: 9,738 Region Association: None |
So there was a local set of carbs for sale and I jumped on what I thought was a pretty good deal.. Any one have anyone install guides I am not going to install them yet but it would be nice to get an idea of whats needed..
Thanks |
sean_v8_914 |
Nov 23 2008, 09:22 PM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
Bosch 009 will work OK but is not optimal. the 009 firing position is 90 deg off from the stock type 4. it is cheap and easy to find. better but still not great would be the Bosch 050. The 009 and 050 are mechanical advance only. you can use a D Jet or L jet distributor that has vacuum advance. the Mallory has been tested and is dyno proven to be best option. you MUST run special plug wires with the Mallory to prevent damage to the optical trigger. I am NOT a big fan of an optical trigger in an automotive environment
Lo-Fi Version | Time is now: 13th June 2024 - 06:02 AM |
