Heat cables, replacing |
Ian Stott |
Dec 2 2008, 12:03 AM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
The cable that pulls the heat flapper open broke off, is there a tech article on how to replace those, may as well do both, if one broke the other is probably not far behind.
Ian Stott Moncton Canada |
Spoke |
Dec 2 2008, 08:22 AM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The cable seems to be nothing more than just a steel wire. I would think the steel wire that can be purchased in spools at a local home improvement/hardware store would work.
Take out a length of the wire, straighten it and bend in half then fish it through the tunnel. Since the originals had the barrel at the end to connect to the flapper, I just got the ends from another cable and wire clamped them onto the new wire. |
SLITS |
Dec 2 2008, 08:25 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
The cable seems to be nothing more than just a steel wire. I would think the steel wire that can be purchased in spools at a local home improvement/hardware store would work. Take out a length of the wire, straighten it and bend in half then fish it through the tunnel. Since the originals had the barrel at the end to connect to the flapper, I just got the ends from another cable and wire clamped them onto the new wire. It's plastic coated, not bare. SS wire would probably be a lot better than straight steel. |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:56 PM |
