Ian Stott
Dec 2 2008, 12:03 AM
The cable that pulls the heat flapper open broke off, is there a tech article on how to replace those, may as well do both, if one broke the other is probably not far behind.
Ian Stott
Moncton
Canada
914Sixer
Dec 2 2008, 08:11 AM
It is a one piece wire that runs to both flapper boxes. There is 3 different cables though. One for the -6, and early and(75-76) late ones for the -4. Order new cable according to year. With that said, I believe one or more is NLA.
jim_hoyland
Dec 2 2008, 08:21 AM
The replacement is pretty easy to replace once you have a new cable. Once the heater handle is removed ( tewo bolts) and pulled out of the tunnel, the wire will follow. If the current cable broke between the firewall and the flapper, you can easily add a piece.
Spoke
Dec 2 2008, 08:22 AM
The cable seems to be nothing more than just a steel wire. I would think the steel wire that can be purchased in spools at a local home improvement/hardware store would work.
Take out a length of the wire, straighten it and bend in half then fish it through the tunnel. Since the originals had the barrel at the end to connect to the flapper, I just got the ends from another cable and wire clamped them onto the new wire.
SLITS
Dec 2 2008, 08:25 AM
QUOTE(Spoke @ Dec 2 2008, 06:22 AM)
It's plastic coated, not bare. SS wire would probably be a lot better than straight steel.
Bartlett 914
Dec 2 2008, 09:32 AM
Since the flapper boxes have the spring in them that does the closing, why can't a braided cable work? Has anyone done this?
newto914s
Dec 2 2008, 08:55 PM
I'm fairly sure the cable plays a role in grounding the circuit to the heater booster fan in the engine compartment. So your choose of materials could determine where that fan continues to work.
Bartlett 914
Dec 3 2008, 02:19 PM
QUOTE(newto914s @ Dec 2 2008, 08:55 PM)
These cables have no electrical function.
r_towle
Dec 3 2008, 03:10 PM
QUOTE(Bartlett 914 @ Dec 3 2008, 03:19 PM)
:agreed:
The floor switch has a ground contact on the bottom of the swtich that performs the electrical function...it also gets really dirty.
Rich
Cevan
Dec 3 2008, 05:34 PM
I had the lever out this spring. It's probably not a bad idea to take the lever apart and clean it up.
r_towle
Dec 3 2008, 06:22 PM
QUOTE(Cevan @ Dec 3 2008, 06:34 PM)
Have your shop vac handy...
Yes clean that one and the Ebrake one...both are grounding switches and both sit at the bottom of a hole full of crap...
Rich
IronHillRestorations
Dec 3 2008, 09:32 PM
I'm guessing the coated single wire cable would act smoother than a stranded cable, that would eventually fray, and abrade the tube.
mike_the_man
Dec 4 2008, 12:56 PM
I went to my local bicycle shop and bought a length of brake cable (or shifter cable). I can't remember how long it was, but it was cheap, less than $5. Crimp some ends on, and you're good to go.
Cheers,
