> to weld or not to weld, vs. POR15 patch
zeezee
post Dec 3 2008, 09:58 PM
I have some rust under the seats (surprise!). I had planned to just use "POR15 Patch" on.
But maybe I should get a couple of these patched with steel&weld?
Welding is beyond my capabilities so I'd have to find a local shop to do it - I don't like others messing with my car plus $$ (IMG:style_emoticons/default/sad.gif)
Opinions?
Driversside...
Driverside firewall...
Pass. firewall/door corner...
Possible structural issues with this one...
Larouex
post Dec 3 2008, 10:08 PM
Larouex
QUOTE(zeezee @ Dec 3 2008, 07:58 PM) *
Looking at the rust you have around the inner-longs and the pan... Have you dug into the hell-hole and other areas on the ourside rockers to get a full evaluation of the rust damage you are dealing with?
Having seen a similiar pattern in two cars I have bought, I was optimistic until I really knew all the places.
As far a welding goes, it is expensive to have someone do it. You can be your own fixer for a little less than $700.00 and with a little practice, you can tackle a lot of the fixes that you see on these forums.
But still you need to know for yourself that your structure is not weakened. Your initial damage in the floorpan looked a lot like mine... <s/>
zeezee   to weld or not to weld   Dec 3 2008, 09:58 PM
SirAndy   Looks like you had some water sitting on those flo...   Dec 3 2008, 10:07 PM
ericread   Looks to me that you don't have much of a choi...   Dec 3 2008, 10:07 PM
Larouex   I have some rust under the seats (surprise!)....   Dec 3 2008, 10:08 PM
Spoke   As far a welding goes, it is expensive to have so...   Dec 4 2008, 11:54 AM
r_towle   bbbbbbbbbbb   Dec 3 2008, 10:14 PM
ConeDodger   That needs to be welded. I second the McMark nomin...   Dec 3 2008, 10:22 PM
LarryR   That needs to be welded. I second the McMark nomi...   Dec 3 2008, 10:26 PM
zeezee   That needs to be welded. I second the McMark nomi...   Dec 4 2008, 01:39 AM
Vacca Rabite   To big for POR. Cut and Weld. Zach   Dec 4 2008, 11:25 AM
9146986   That's way beyond anything you can buy from PO...   Dec 4 2008, 01:37 PM
Todd Enlund   Yes, it can be repaired, but it ain't gonna b...   Dec 4 2008, 02:52 PM
jd74914   Yes, it can be repaired, but it ain't gonna ...   Dec 4 2008, 03:42 PM
charliew   If I were you I would dig all the sealer out on th...   Dec 4 2008, 02:27 PM
zeezee   Sealer has been dug out and there isn't anymor...   Dec 4 2008, 06:02 PM
Cevan   Sealer has been dug out and there isn't anymo...   Dec 5 2008, 12:10 PM
sww914   How much do you want for the fingernail? :)   Dec 4 2008, 06:19 PM
brant   ouch... a reputable shop really any shop whose w...   Dec 4 2008, 10:45 PM
Vacca Rabite   Get a welder and just start practicing. Many of u...   Dec 5 2008, 10:16 AM
rjames   Get a welder and just start practicing. Many of ...   Dec 5 2008, 11:17 AM
zeezee   OK - I'll give welding a try. What kind of we...   Dec 5 2008, 12:05 PM
Larouex   OK - I'll give welding a try. What kind of w...   Dec 5 2008, 09:02 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:52 AM
