/6 guys - need piston help |
ahdoman |
Dec 5 2008, 06:45 PM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
I've got a 2.4T (73 1/2) that I have torn down. This is what the pistons look like that are in the engine...
What's the difference between these and these that are typically on eBay... Also, These are both 84mm. Since they list these pistons as for a 2.2 / 2.4 is it just a different stroke between the 2 engines? If that's the case are the cylinders interchangeable? |
sixnotfour |
Dec 6 2008, 12:04 AM
914 Wizard Group: Members Posts: 10,437 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE I'd like to ditch the old iron cylinders and use something like the birels to get better heat dissapation. Other than the 84mm ID, are the jugs the same dimensions for both the 2.2 and 2.4 engines? Yes , but there is 0, 1, 2 factory tolerance groups. I have 6 new 2.4 cis pistons . I used the iron cylinders, as they were new. |
Lo-Fi Version | Time is now: 13th June 2024 - 01:18 PM |
