budman5201 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 ![]() |
I dropped my engine over the past week to fix misc oil leaks....oil cooler, front main seal, and the pushrod tubes. All leaked looked fixed but i accidentally overfilled oil by one quart. (drained oil while on ramps, and then refilled with 4 quarts) So i believe that there was one quart still i there when i refilled it 4 quarts on oil change. The dipstick measured 1 quart overfilled when checked.
I only ran it 5 minutes on ramps to get it up to temperature to make sure everything was allright then shut off. The front main seal (looks like from the leak up front dripping from front of fan shroud) like it is leaking. It has a brand new front main seal, IS it TRASHED now? Of am i just seeing the left over oil from the initial overfill thats still in the fan shrould? It now measures EXACTLY right below top notch on dipstick, maybe a hair below.... It leaks still front front of engine, not as fast, but drips a lot. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,597 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
overfilling of oil wont create an oil leak.
What it would do is swamp the valve covers and you would burn alot of oil... The leak is from a seal, could just be the oil cooler seals... Look up (after you wipe it all down) above and in front of the oil filter for slight oozing or running...that will make it to the fan and shoot everywhere. Rich |
budman5201 |
overfilling of oil wont create an oil leak. What it would do is swamp the valve covers and you would burn alot of oil... The leak is from a seal, could just be the oil cooler seals... Look up (after you wipe it all down) above and in front of the oil filter for slight oozing or running...that will make it to the fan and shoot everywhere. Rich those oil cooler seals are brand new...not coming from there. Coming from front fan, dripping litterally from bottom of oil pump it looks like and onto the engine support bar |
Lo-Fi Version | Time is now: 20th June 2024 - 12:39 PM |
