How to Remove Side Panels?, Want to check the longs! |
jesiv |
Dec 26 2008, 10:40 PM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
Ok so how do you remove side panels? Just drill out the rivets? (IMG:style_emoticons/default/WTF.gif) And then how do you re-install? (IMG:style_emoticons/default/blink.gif)
Pics and advice would help! Regards, James |
r_towle |
Dec 27 2008, 12:51 AM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
because you will want to do this every year I suggest screws.
I put them back in with small stainless screws to they can easily come off again. Also, on the bottom, put 1/4 thick rubber washers between the rocker covers and the longitudinal...this keeps a space there that allows water and dirt a route to fall out. Rich |
ericread |
Dec 27 2008, 02:34 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
because you will want to do this every year I suggest screws. I put them back in with small stainless screws to they can easily come off again. Also, on the bottom, put 1/4 thick rubber washers between the rocker covers and the longitudinal...this keeps a space there that allows water and dirt a route to fall out. Rich (IMG:style_emoticons/default/agree.gif) You'll want to takes these off on a yearly basis to remove the accumulated dirt and to inspect the longs. Use SS screws - they actually look pretty good. Eric |
Lo-Fi Version | Time is now: 10th June 2024 - 03:54 PM |
