How to Remove Side Panels?, Want to check the longs! |
jesiv |
Dec 26 2008, 10:40 PM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
Ok so how do you remove side panels? Just drill out the rivets? (IMG:style_emoticons/default/WTF.gif) And then how do you re-install? (IMG:style_emoticons/default/blink.gif)
Pics and advice would help! Regards, James |
boxstr |
Dec 27 2008, 07:02 PM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
If you want to do a complete removal you will need to remove or drill out all of the rivets. Then the three ten MM screws on the bottom that hold the rocker panels on, they are usually so rusty that they break off. You can drill them out later or drill next to them and use stainless screw to hold the panel in place.
Then there are the two screws, these are located on either end. Usually tough to get at, so you may want to jack the car up to make it easier to get to them. Some have a small nut and bolt, plus the rubber spacers. For those you can use rubber hose cut to the same thickness. Aluminum pop rivets are cheap, that is usually the way I secure the top of the panels. CCLINRIVETTHIS |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:19 AM |
