oil cooler 13mm nuts are making me nuts! |
Jerry75914 |
Dec 27 2008, 06:45 PM
Member Group: Members Posts: 124 Joined: 13-October 08 From: Half Moon Bay, CA Member No.: 9,640 Region Association: Northern California |
Hi guys!
I'd appreciate some help...I'm replacing the oil cooler seals, but can't seem to find the last 13mm nut. I have the three 10mm nuts off of the long studs, and one 13mm off of the bracket that supports the passenger side of the cooler, it is up top on the front side of the car. Where is the second 13mm nut? I see a "support bar" in the AA parts diagram, but where is it? The cooler is sliding about 3/4", but that's not enough, and I don't want to force it further if there is still a nut tryong to hold on...help! I have a '75, with super-well-located heat exchangers right in the way... thanks! Jerry |
Jerry75914 |
Dec 27 2008, 07:57 PM
Hi Eric,
Sorry, should have mentioned that...the engine is in. I have the nut off of bracket 4, but I can't find bracket 5. Is it over on the same side as the three studs? It's sliding about 3/4" now, but I would like for it to slide all the way to the wall if possible. Thanks! |
Lo-Fi Version | Time is now: 11th June 2024 - 10:07 AM |
