CHT Cylinder head Temperature, installation |
jc914 |
Dec 28 2008, 10:17 AM
Member Group: Members Posts: 289 Joined: 15-September 08 From: Miami, Florida Member No.: 9,548 Region Association: South East States |
I have finally got the gauges installed in the car and the wires to the engine bay. (cht and oil pressure) I have been doing searches on the forum but i still have one question. To install the cht senor on cylinder 3 do i have to remove the tin on the engine if yes can it be done without dropping the engine, or can i just use a plug socket with cutting out a notch for the wire to go through.
thanks jc |
7275914911 |
Dec 28 2008, 10:46 AM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
I have finally got the gauges installed in the car and the wires to the engine bay. (cht and oil pressure) I have been doing searches on the forum but i still have one question. To install the cht senor on cylinder 3 do i have to remove the tin on the engine if yes can it be done without dropping the engine, or can i just use a plug socket with cutting out a notch for the wire to go through. thanks jc I ground off one corner of an extension. Worked like a champ. Good Luck JKP |
Lo-Fi Version | Time is now: 11th June 2024 - 10:24 AM |
