| VaccaRabite |
Dec 29 2008, 10:46 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,929 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
(IMG:http://farm4.static.flickr.com/3201/3147134237_5740914ecd.jpg)
As can be seen from the picture above, I do not have enough accelerator cable to reach the throttle linkage. The cable is a Terry cable. What am I doing wrong? The cable needs to extend about 10 inches out of its sheath, but only extends about 3.5 inches. Is this an adjustment I need to make at the pedal end? I have PLENTY of total cable left, but the pull I have is just about perfectly 90degrees to the linkage arm. Am I just going to have to re-design the cable mount to bring it closer to the linkage? Zach |
| Type 4 Unleashed |
Dec 29 2008, 12:09 PM
CREATIVE TYPE lV ENGINEERING ![]() ![]() ![]() Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
As can be seen from the picture above, I do not have enough accelerator cable to reach the throttle linkage. The cable is a Terry cable. What am I doing wrong? The cable needs to extend about 10 inches out of its sheath, but only extends about 3.5 inches. Is this an adjustment I need to make at the pedal end? I have PLENTY of total cable left, but the pull I have is just about perfectly 90degrees to the linkage arm. Am I just going to have to re-design the cable mount to bring it closer to the linkage? Zach Hi Zach As was previously mention, you've lost some cable some where or the cable was packaged for the wrong app ? The stock GEMO replacement cable has a plastic tube for the cable about the length of what your showing in the pic, so your short at least 5 or 6". But your cable mount to the fan shroud is too far away, you will need a bracket of some sorts to mount the cable about the distance the dist is from the lever, and the lever may have to be moved up one more section on the cross shaft ? And Red Blue & Green are good color combos. |
Vacca Rabite Accelerator cable question Dec 29 2008, 10:46 AM
Gint You sure you don't have the cable wrapped arou... Dec 29 2008, 10:52 AM
r_towle Follow the end of the bolen (sheath) of the cable.... Dec 29 2008, 11:24 AM
Phoenix 914-6GT
As can be seen from the picture above, I do not h... Dec 29 2008, 12:26 PM
jcambo7 Now thats purty Jonny! :D :headbanger: :driv... Dec 29 2008, 02:05 PM
Vacca Rabite It would appear that I am wrapped around the clutc... Dec 29 2008, 12:22 PM
Phoenix 914-6GT Yes it is... It's Triad :headbanger: I think t... Dec 29 2008, 02:07 PM
jcambo7
Yes it is... It's Triad :headbanger: I think ... Dec 29 2008, 02:09 PM
maf914 Zach and Jon,
Jon's picture may be the answer... Dec 29 2008, 03:58 PM
Phoenix 914-6GT
Zach and Jon,
Jon's picture may be the answe... Dec 29 2008, 04:53 PM
johnnie5 I am in the process of setting up new carb linkage... Dec 29 2008, 04:35 PM
Vacca Rabite Johnnie5, I like that throttle holder.
It is prett... Dec 29 2008, 04:53 PM
Phoenix 914-6GT
It is pret... Dec 29 2008, 04:55 PM
Bruce Hinds It's all toooo easy to get the cable "loo... Dec 29 2008, 06:17 PM
johnnie5 Zach,
Those pics are of Grimsteads car, I haven... Dec 29 2008, 07:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th October 2026 - 11:53 PM |
