> Accelerator cable question
VaccaRabite
post Dec 29 2008, 10:46 AM
En Garde!
(IMG:http://farm4.static.flickr.com/3201/3147134237_5740914ecd.jpg)
As can be seen from the picture above, I do not have enough accelerator cable to reach the throttle linkage.
The cable is a Terry cable.
What am I doing wrong? The cable needs to extend about 10 inches out of its sheath, but only extends about 3.5 inches. Is this an adjustment I need to make at the pedal end?
I have PLENTY of total cable left, but the pull I have is just about perfectly 90degrees to the linkage arm. Am I just going to have to re-design the cable mount to bring it closer to the linkage?
Zach
Type 4 Unleashed
post Dec 29 2008, 12:09 PM
CREATIVE TYPE lV ENGINEERING
Group: Retired Members
QUOTE(Vacca Rabite @ Dec 29 2008, 08:46 AM) *
Zach
Hi Zach
As was previously mention, you've lost some cable some where or the cable was packaged for the wrong app ? The stock GEMO replacement cable has a plastic tube for the cable about the length of what your showing in the pic, so your short at least 5 or 6".
But your cable mount to the fan shroud is too far away, you will need a bracket of some sorts to mount the cable about the distance the dist is from the lever, and the lever may have to be moved up one more section on the cross shaft ?
And Red Blue & Green are good color combos.
PeeGreen 914
post Dec 29 2008, 12:26 PM
QUOTE(Type 4 Unleashed @ Dec 29 2008, 10:09 AM) *
Zach
Hi Zach
jcambo7
post Dec 29 2008, 02:05 PM
Now thats purty Jonny! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/driving.gif)
- Lo-Fi Version Time is now: 30th October 2026 - 11:52 PM
