| Bartlett 914 |
Jan 8 2009, 09:21 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,219 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
We all do it. We sometimes need a tool for a special use. It sometimes makes the difference in how well a job comes out Earlier this year, just for the heck of it, I removed the shaft from the bushings in an old trailing arm. I ended up using heat. I did get it out but what a an awful stinky mess! Yesterday Glenn (gms) stopped by with 2 trailing arms he was cleaning up. He wanted to know if I had a press for the job. With a little scrap metal some machining and welding we came up with a simple tool to remove the shaft. Here are a couple pictures of what we came up with. The tool worked really nice. I think if wanted, this would also work with the trailing arm in the car.
So how about posting some of the special tools you have made. Attached image(s)
| aircooledtechguy |
Jan 8 2009, 11:13 AM
The Aircooledtech Guy ![]() ![]() ![]() Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
Here's a couple things:
The first is a super cheap and effective DIY Soda Blaster The other is just a couple Spark Plug Tools that make changing the plugs easier |
| Bartlett 914 |
Jan 8 2009, 11:22 AM
Here's a couple things: The first is a super cheap and effective DIY Soda Blaster The other is just a couple Spark Plug Tools that make changing the plugs easier I like your soda blaster. For cleaning the carburetor you showed, how much soda did you end up using? |
| aircooledtechguy |
Jan 8 2009, 01:50 PM
I like your soda blaster. For cleaning the carburetor you showed, how much soda did you end up using? For that pair of 356 carbs, I think I used around 2 pounds. I bought a large box (I think it was 3 pounds) and had around 1/3 box left. 'Course @ $1.00 or so for a 1 pound box, it's ridiculously cheap. It's one time use media so no need to splash-out for the "boutique" Arm & Hammer brand, the generic stuff is all you need. . . (IMG:style_emoticons/default/biggrin.gif) |
Bartlett 914 Home made tools Jan 8 2009, 09:21 AM
URY914 I kinda like by engine crossbar wheels. It's n... Jan 8 2009, 09:44 AM
Bartlett 914
I kinda like by engine crossbar wheels. It's ... Jan 8 2009, 09:52 AM
marks914 Here is my version of the engine installation tool... Jan 8 2009, 10:48 AM
Dr Evil I removed my /6 and tranny together last night and... Jan 8 2009, 10:56 AM
SGB Yeah Nate, that extended plug socket is good. I d... Jan 8 2009, 11:27 AM
Jeff Bowlsby My D-Jet break-out box: Jan 8 2009, 02:30 PM
Bartlett 914 My Brake bleeder. Probably the simplest of tools b... Jan 8 2009, 03:19 PM
HAM Inc Those are some neat tools! I really like the a... Jan 8 2009, 04:06 PM
scotty b My English wheel and my shrinker / stretcher I con... Jan 8 2009, 06:54 PM
r_towle B)-->
scotty b some guy on E-bay seveal years ago. I really don... Jan 8 2009, 08:17 PM
URY914 I made an extension for my floor jack. When I jack... Jan 8 2009, 07:09 PM
URY914 I welded a old socket on the bottom of it to go in... Jan 8 2009, 07:10 PM
URY914 I also get comments on the jack stand blocks. Who ... Jan 8 2009, 07:12 PM
URY914 I build this tool box/welding cart too... Jan 8 2009, 07:16 PM
URY914 The frame in made of scrap Unistrut steel from a j... Jan 8 2009, 07:19 PM
URY914 I found these bad boys at a auto show and really w... Jan 8 2009, 07:23 PM
smontanaro Can we just skip the obligatory waiting period and... Jan 8 2009, 07:37 PM
Todd Enlund
Can we just skip the obligatory waiting period an... Jan 8 2009, 07:59 PM
911quest Here is my work in progress a P258c for seting pin... Jan 8 2009, 07:45 PM
Dr Evil
Here is my work in progress a P258c for seting pi... Jan 8 2009, 07:46 PM
Zimms
Here is my work in progress a P258c for seting pi... Jan 9 2009, 08:36 PM
911quest
Here is my work in progress a P258c for seting p... Jan 10 2009, 09:31 PM
Zimms
[quote name='Zimms' post='1119775' date='Jan 9 20... Jan 10 2009, 11:22 PM
r_towle I want a plasma cutter...my head hurts thinking ab... Jan 8 2009, 08:20 PM
scotty b Yeah most likely overkill as I used 3/8 plate for ... Jan 8 2009, 08:24 PM
RJMII http://inlinethumb26.webshots.com/43161/2593686280... Jan 8 2009, 11:53 PM
wertygrog here's a super flat 22mm wrench for tensioning... Jan 8 2009, 11:57 PM
zambezi Heres an engine stand I built for storing and runn... Jan 9 2009, 01:18 AM
Bartlett 914
Heres an engine stand I built for storing and run... Jan 9 2009, 08:51 AM
zambezi
Heres an engine stand I built for storing and ru... Jan 11 2009, 12:26 AM
michelko My Engine Test stand
and the tool to check fuel... Jan 9 2009, 08:58 AM
Todd Enlund
and the tool to check fuellevel in zenith carbs
... Jan 9 2009, 12:50 PM
aircooledtechguy Here's my engine run stand and the starter box... Jan 9 2009, 11:25 AM
andys I've got several custom jigs and fixtures, but... Jan 9 2009, 02:56 PM
roadster fan
I've got several custom jigs and fixtures, bu... Jan 9 2009, 04:16 PM
MrKona Here's my transaxle driveshaft holder tool. Ke... Jan 9 2009, 03:19 PM
roadster fan Here is one that I made after having to remove the... Jan 9 2009, 04:37 PM
914dave
Here's the rotisserie pix's Jan 9 2009, 05:15 PM
J P Stein Wanna check backlash on the R&P of your 901? H... Jan 9 2009, 07:34 PM
MrKona
Wanna check backlash on the R&P of your 901? ... Jan 9 2009, 10:23 PM
J P Stein
I like the backlash measurement set up. Do you ... Jan 10 2009, 10:47 AM
carr914 This thread would not be complete without FourBlad... Jan 9 2009, 09:32 PM
sean_v8_914 suspension bushing reamer Jan 10 2009, 10:09 AM
rick 918-S I made these for doing large deep shrinks. You sli... Jan 10 2009, 01:57 PM
rick 918-S Here is the result or close to it.
McMark Revival!
I found a tool I made awhile ago. 9... Jan 19 2009, 09:53 PM
highways Here's my favorite 'found object'. My ... Jan 20 2009, 03:49 AM
Dr Evil
Here's my favorite 'found object'. My... Jan 28 2009, 04:46 PM
McMark That's a cool kit! Jan 20 2009, 08:46 PM
URY914 No, it's a TOOL kit. Jan 20 2009, 09:23 PM
MrKona Here's my home made blasting cabinet. I just f... Jan 28 2009, 01:13 AM
Todd Enlund
Here's my home made blasting cabinet. I just ... Feb 1 2009, 11:35 AM
cwpeden I made my own blasting cabinet too and used my sho... Jan 28 2009, 01:41 AM
scotty b Yeah you really can't beat Thompsons prices bu... Jan 28 2009, 06:44 PM
rick 918-S I'm not sure if you would classify 2" mas... Jan 30 2009, 08:39 AM
highways
I couldnt resist this deal on the cigars, but be... Jan 30 2009, 06:51 PM
zig-n-zag tranny nut buster.... http://i631.photobucket.com/... Jan 31 2009, 07:48 PM
majkos I'm suprise no one made a Engine Head Sensor t... Feb 1 2009, 09:59 AM
majkos
Simple 13mm socket, 914 jack handle, cut at a ... Feb 1 2009, 10:20 AM
Sleepin ......and I am missing your Superbowl party.... :W... Feb 1 2009, 11:15 AM
Gint You've never been to Kevin's?!?! ... Feb 1 2009, 11:22 AM
majkos
You've never been to Kevin's?!?! ... Feb 1 2009, 02:16 PM
Wilhelm [size=5]Ball Joint Remover
[center]So I don... Feb 2 2009, 10:11 PM
McMark Nice work. Feb 3 2009, 12:49 AM
Racer Chris Delrin rear bushing cutting tools
Top: Sleeve th... Feb 5 2009, 09:23 AM
larss Rear boot torsion bar tool
Made this tool for fit... Sep 22 2009, 01:15 AM
charliew I don't remember where I saw it but the fiero ... Sep 22 2009, 08:24 AM
jimkelly bearing removal tool - not mine
see thread
http... Apr 28 2010, 07:21 AM
McMark Made another tool today. This piece fits tightly ... Jul 28 2010, 02:01 PM
rdauenhauer Here is one that is surprisingly simple but I find... Jul 30 2010, 09:35 PM
rdauenhauer here is THE tool for unlocking the rear boot :D
... Jul 30 2010, 09:37 PM
Jeff Bowlsby
here is THE tool for unlocking the rear boot :D ... Aug 12 2010, 01:07 PM
charliew
here is THE tool for unlocking the rear boot :D... Aug 13 2010, 05:34 PM
charliew A picture of you using that tool would be interest... Jul 31 2010, 01:05 PM
larss Handle made when fitting the rear window, one in e... Aug 12 2010, 02:50 AM
McMark :lol4: Love it, Lars! That's awesome. Aug 12 2010, 11:22 AM
Richard Casto
... Aug 12 2010, 01:13 PM
Phoenix-MN Let's kick it up a notch This isn't 914 ... Aug 12 2010, 06:23 PM
charliew That is neat but it would take me three days to bu... Aug 13 2010, 05:27 PM
Bartlett 914
That is neat but it would take me three days to b... Aug 13 2010, 05:33 PM
rick 918-S
That is neat but it would take me three days to ... Aug 14 2010, 02:42 PM
Phoenix-MN
That is neat but it would take me three days to b... Aug 14 2010, 02:31 PM
qa1142
[quote name='charliew' post='1356147' date='Aug 1... Aug 14 2010, 02:40 PM
rudedude I'd even pay you something for your time :tro... Aug 14 2010, 03:00 PM
qa1142 that is the $25
I would even add a paypal fe... Aug 14 2010, 03:06 PM
charliew I would think 300.00-500.00 might cover the labor Aug 14 2010, 03:09 PM
Phoenix-MN
I would think 300.00-500.00 might cover the labo... Aug 14 2010, 05:15 PM
qa1142
[quote name='charliew' post='1356452' date='Aug 1... Aug 14 2010, 05:22 PM
sixnotfour Towing aid without removing axles. Aug 28 2010, 05:56 PM
Dr Evil That looks dangerous :blink: Aug 28 2010, 07:03 PM
John
First pic shows:
914 Rotisserie
Engine stand
My... Aug 28 2010, 09:06 PM
rick 918-S I had a very rusty caliper I made this clamp with ... Sep 21 2010, 10:43 PM
rick 918-S :) Sep 21 2010, 10:44 PM
rick 918-S :) Sep 21 2010, 10:46 PM
rick 918-S :) Sep 21 2010, 10:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd October 2026 - 07:13 PM |
