License Plates, Need a period-correct plate ? |
jim_hoyland |
Jan 13 2009, 12:50 PM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I needed a replacement front license plate and wanted one with the correct 1975 color scheme. These guys make plates for nearly any state and period. The size and coloration were exactly the same as my original back plate:
http://www.licenseplates.tv/cat/usa_state_plates_1.html |
Joe Bob |
Jan 13 2009, 06:50 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Yellow background plates with black letters can be used IF they were for a car from the years they were issued...they assign them like vanity plates unless you can prove they were on the car before.
Black backgrounds with yellow letters are in the process of being approved like the above. CA DMV calls it the YOM program. The TV Reeproduction License plates, are aluminum. Reals ones aren't. Otherwise they are virtually indistinguiseable. You would have to remove them from the car and the frame to tell the difference. |
ericread |
Jan 13 2009, 07:32 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Yellow background plates with black letters can be used IF they were for a car from the years they were issued...they assign them like vanity plates unless you can prove they were on the car before. Black backgrounds with yellow letters are in the process of being approved like the above. CA DMV calls it the YOM program. The TV Reeproduction License plates, are aluminum. Reals ones aren't. Otherwise they are virtually indistinguiseable. You would have to remove them from the car and the frame to tell the difference. The YOM program only allows 1969 or older cars/plates to be re-issued (1972 and older for commercial vehicles). You need the appropriate year sticker (1969 or older) on the plate, and you need both front and rear plates. Eric Read |
kconway |
Jan 13 2009, 08:08 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
Yellow background plates with black letters can be used IF they were for a car from the years they were issued...they assign them like vanity plates unless you can prove they were on the car before. Black backgrounds with yellow letters are in the process of being approved like the above. CA DMV calls it the YOM program. The TV Reeproduction License plates, are aluminum. Reals ones aren't. Otherwise they are virtually indistinguiseable. You would have to remove them from the car and the frame to tell the difference. The YOM program only allows 1969 or older cars/plates to be re-issued (1972 and older for commercial vehicles). You need the appropriate year sticker (1969 or older) on the plate, and you need both front and rear plates. Eric Read No, any plate prior to 1963. Which is why Mike says "yellow background with black lettering. from the DMV website: YOM plates are any officially manufactured California license plates issued prior to 1963 that the department determines are legible and serviceable pursuant to California Vehicle Code ยง5004.1. |
Lo-Fi Version | Time is now: 9th June 2024 - 05:34 AM |
