How to install Steel Fender Flares on a 914:, Got a visit from one of our Canadian 914 guys this weeked |
Root_Werks |
Nov 9 2008, 07:07 PM
Village Idiot Group: Members Posts: 8,331 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I got home Saturday just around noonish and notice this hanging out at my house:
Attached image(s) |
pete-stevers |
Jan 14 2009, 05:19 PM
saved from fire! Group: Members Posts: 2,642 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
i am planning to do the final block with 800 wet
Is there any problem with blocking the color with 1200 wet in between coats of color?? |
scotty b |
Jan 14 2009, 05:43 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
i am planning to do the final block with 800 wet Is there any problem with blocking the color with 1200 wet in between coats of color?? Assuming it is a solid color 600-1000 tops. The higher grade you sand it to the less the clear has to adhere to, the easier it is to run the clear. NEVER EVER sand a metallic base, you WILL ruin it. I see no need in all honesty in sandiong the base anyway unless there is something in it. You'll get a better result wet sanding the clear then reclearing it |
Lo-Fi Version | Time is now: 1st June 2024 - 03:16 AM |
