| JWest |
Mar 25 2007, 09:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,665 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None
| 914werke |
Jan 16 2009, 06:54 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,606 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
These are (OE?) knurled rod ends that need to be welded in place of existing OE set pin ends on the (bent) R. (intermediate) shift rod ©? sort of - you could cut equivalent parts to these from a 914 steering shaft. These get welded to a short center section of the bent factory shift tube. One more question, when you cut off both ends of the OE bent shift rod you lose the taper that reduces the tube down to the dimension of the knurled rod? How do you suggest to correct for this prior to welding. Speaking of welding.. the Factory drilled and filled 4 rosettes about an 1" from the end of the tube, is that necessary or are simple spots or a bead ran around the tube end all that is required? |
James Adams Side-shift linkage kit Mar 25 2007, 09:40 PM
SirAndy i just ordered my kit! :headbanger:
that, ... Apr 2 2007, 05:22 PM
dr914@autoatlanta.com We would love to see some pics of this unit instal... Apr 9 2007, 02:41 PM
James Adams Here is a thread with some installation shots - be... Apr 9 2007, 03:49 PM
James Adams I am currently debating whether to produce another... Feb 20 2008, 11:35 AM
michaelt55 I am interested in one..depending on whether I hav... Feb 22 2008, 11:17 PM
rdauenhauer Id be interested in one.
But one detraction is th... Feb 23 2008, 12:05 AM
dbu356 I would also be interested in one.
Thanks
Dave Feb 23 2008, 11:19 AM
Lou W I'd buy one. :) Feb 24 2008, 12:14 AM
Van914 James,
Yes, I am interested also.
Van914 Feb 25 2008, 07:37 AM
rdauenhauer So James I take it you are out of stock now? Feb 25 2008, 11:29 PM
Phoenix 914-6GT Yes he is. That is why I went with some of the Pat... Feb 26 2008, 01:49 AM
James Adams Yes, I'm out of stock. Thanks for the feedbac... Feb 26 2008, 06:19 AM
BKLA This is a great product! Installed (partially,... Feb 26 2008, 12:04 PM
rdauenhauer James any update? :confused: May 9 2008, 12:45 PM
James Adams
It will be availab... May 12 2008, 03:38 PM
michaelt55 any new upgrades, improvements?
James any... May 17 2008, 07:38 PM
James Adams
It should be ava... May 19 2008, 08:57 AM
Phoenix 914-6GT That would be awsome. I only need the rear portion... May 19 2008, 12:21 PM
ClayPerrine When can we order? May 19 2008, 12:26 PM
James Adams
When can we order?
I have all the parts but I w... May 19 2008, 12:33 PM
James Adams New kits are now available - check it out here:
L... May 27 2008, 04:22 PM
rdauenhauer :trophy:
Now for the questions: :D
Being the C... May 28 2008, 09:26 PM
James Adams
:trophy:
A is a O... May 28 2008, 09:52 PM
rdauenhauer
So are the dimensions for this available? I looke... May 29 2008, 02:09 AM
James Adams
So are the dimensions for this available? I look... May 29 2008, 06:45 AM
70Sixter
I though the point ot the kit was to eliminate th... May 31 2008, 03:03 PM
James Adams
Does that mean the kit works as is on a stock -... Jun 1 2008, 09:15 AM
rdauenhauer James reading the instructions to re-use the stock... Jun 7 2008, 12:13 AM
James Adams
James reading the instructions to re-use the stoc... Jun 7 2008, 07:42 AM
JWest
One more question, when you cut off both ends of ... Mar 9 2009, 08:02 AM
JWest I've got new lower prices on the linkage kits,... Nov 10 2009, 06:38 AM
nsr-jamie Someday when I have more money and take care of so... Nov 11 2009, 06:08 AM
Phil Plummer
Someday when I have more money and take care of s... Mar 14 2012, 09:19 PM
Phil Plummer Hi I have a 71 and I drove the car home and starte... Feb 1 2012, 11:48 PM
lonewolfe Hey Phil,
It's Mark, again. We've been ta... Mar 21 2012, 09:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:16 AM |
