| Richard Casto |
Apr 22 2007, 10:29 AM
Blue Sky Motorsports, LLC ![]() ![]() ![]() Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
I am about to pull the trigger on a 911 front suspension. It is billed as being from a 72-74 911S (no the aluminum calipers are gone and I will be using regular A calipers instead) as it has KONI struts with the 3.5” spacing. Ultimately I am looking to install KONI Sport (aka Yellow) struts that have the adjustment knob on the top. I have read a few quality threads such as…
http://www.914world.com/bbs2/index.php?sho...c=390&st=20 This answers a lot of questions, but that thread mostly talks about Boge struts, spindle mods, etc. and doesn’t 100% clear up a question I have about KONI insert compatibility. My confusion comes from the KONI application guide http://www.koni-na.com/pdfcatalogs/2007applguide.pdf (approx 1 MB PDF). If you don’t want to look at the PDF here is a summary of the KONI document … 65-68 911 Boge strut 86-1394 Classic KONI strut 86-1308 Classic 69-74 911 Boge strut 8641-1039 Classic KONI strut 86-1638 Classic 75-89 911 Boge strut 8641-1039 Special KONI strut 86-1942 Special (footnote) 8641-1039 Sport 914 and 914/6 All (Boge?) 8641-1077 Sport To translate KONI types, Classic = “Black”, Special = “Red” and Sport = “Yellow”. The implication is that "it appears" that you are really limited if you want to use the “Sport” insert as they only list the “Sport” strut for the 914 and 914/6 as well as for the 75-89 911 (but with a cryptic footnote). The 911 footnote says… “Ext. adjust Sport alternative (both Boge and KONI) for OE KONI struts, gland nut 73.25.01.011.1 must be ordered separately” My confusion/questions…
One last thing… I have tried to document everything that I have learned on the 914 Wiki. Please feel free to look at that article and if you think you know what you are talking about, correct any mistakes. http://www.roadglue.com/wiki/index.php/911_front_suspension |
| Eric_Shea |
Feb 10 2009, 06:13 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
You're going Koni to Koni so your pitch on those struts will be the same. Why would you need a new nut?
I'm rather taken aback that you're not sending those to me. (IMG:style_emoticons/default/mad.gif) Oh well, I think you should hurry and finish them off, display them quite proudly in your house and take a picture of them. Then... every time you visit Marke, whip out the picture and tell him to "hurry up... the struts are waiting!" (IMG:style_emoticons/default/w00t.gif) |
| Richard Casto |
Feb 11 2009, 07:29 AM
You're going Koni to Koni so your pitch on those struts will be the same. Why would you need a new nut? I think the vast majority of the replacements struts sold are for Boge struts since those are the most common type. So I believe that when Koni packages up the inserts, they include a centering ring and nut that works with the Boge strut (or maybe you re-use the Boge nut, I am not sure). Regardless, if you are going to use the OEM Koni strut, then you need the special gland nut because the Koni strut nut is different than the Boge strut nut (different thread, etc.) You also can't reuse the nut that is on the OEM strut as it has the right threads but otherwise the wrong shape to hold the newer insert into place. The Koni application PDF list the gland nut and I think Roman has the right number in his earlier post. So in short, there is slightly more work/parts needed to put a Koni insert into a Koni strut. (IMG:style_emoticons/default/smile.gif) |
Richard Casto Yet another 911 strut thread Apr 22 2007, 10:29 AM
skline Didn't the 3.5 spacing come on the later cars?... Apr 22 2007, 10:55 AM
Eric_Shea
3.5" began in 1969 with the first Koni stru... Apr 22 2007, 12:02 PM
Eric_Shea Actually, this shows the flare in the tube better ... Apr 22 2007, 12:16 PM
Richard Casto Eric, thanks for jumping in! :D
The photos o... Apr 22 2007, 12:43 PM
Eric_Shea I really don't think you'd be able to use ... Apr 22 2007, 01:51 PM
Richard Casto Ok, I talked to Bob at KONI and Jason at Paragon (... Apr 23 2007, 03:37 PM
Eric_Shea
No I won't... :D
After my chats with Koni t... Apr 23 2007, 08:42 PM
rdauenhauer
Ok, I talked to Bob at KONI and Jason at Paragon ... Feb 8 2009, 11:28 PM
Richard Casto Rich,
I am not sure what your question is. You q... Feb 9 2009, 08:13 AM
Richard Casto Here is a photo of my KONI strut and the 8641-1039... Feb 9 2009, 08:21 AM
rdauenhauer Danm~! :angry: :headbang:
:welder: Feb 9 2009, 05:14 PM
veltror Apologies for the hijack but I think I might be ab... Feb 10 2009, 02:29 PM
Eric_Shea Those are non-usable junk. Please send them to me... Feb 10 2009, 02:40 PM
Eric_Shea Let me come back around to this...
If they need r... Feb 10 2009, 02:58 PM
Richard Casto Roman,
That is the exact same strut that I have (... Feb 10 2009, 03:55 PM
Richard Casto Forgot to mention this. You need to fill the spac... Feb 10 2009, 04:02 PM
Eric_Shea :agree: It's listed, with the fluid volume nee... Feb 10 2009, 04:13 PM
veltror You guys are great, so I could just order two 8641... Feb 10 2009, 06:04 PM
veltror :idea:
I wish I was still living in the US, all ... Feb 10 2009, 06:16 PM
Eric_Shea Joking... I meant "I'm rather taken aback... Feb 10 2009, 06:23 PM
ericread Eric Shea;
Aren't you out of the business now... Feb 11 2009, 11:00 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 09:42 AM |
