More than a shifter adjustment |
sEEkEr |
Feb 22 2009, 12:32 PM
Newbie Group: Members Posts: 18 Joined: 25-August 08 From: 3rd Stone from the Sun.... Member No.: 9,461 Region Association: South East States |
Well...the car is stuck in the 1st/Reverse plane....no manner of adjustment will move the shift arm to 2-3-4-5....
Shift arm is not binding, set screws are tight. I can manually rotate the shift arm clockwise, but the shifterdoes not... Shifter mechanism looks fine, almost as new...what am I missing here?????? TIA Brodie |
echocanyons |
Feb 22 2009, 12:37 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
Knowing next to nothing about transmissions except what I learned from the good doctors trans course, I would guess the trans is stuck in two gears.
Did you tray and disconnect the linkage and move the selector at the trans? |
sEEkEr |
Feb 22 2009, 12:43 PM
Knowing next to nothing about transmissions except what I learned from the good doctors trans course, I would guess the trans is stuck in two gears. Did you tray and disconnect the linkage and move the selector at the trans? Hey Kelly, I can put it in first and drive it, and I can put it in reverse. And yes, I can manually move the selector with a pipewrench. It seems the shifter is not rotating the shift rod properly.... |
Lo-Fi Version | Time is now: 8th June 2024 - 08:37 AM |
