More than a shifter adjustment |
sEEkEr |
Feb 22 2009, 12:32 PM
Newbie Group: Members Posts: 18 Joined: 25-August 08 From: 3rd Stone from the Sun.... Member No.: 9,461 Region Association: South East States |
Well...the car is stuck in the 1st/Reverse plane....no manner of adjustment will move the shift arm to 2-3-4-5....
Shift arm is not binding, set screws are tight. I can manually rotate the shift arm clockwise, but the shifterdoes not... Shifter mechanism looks fine, almost as new...what am I missing here?????? TIA Brodie |
Dr Evil |
Feb 22 2009, 05:40 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Did your car come with a side shifter? Was it converted to a side shifter? What kind of coupler do you have at the bottom of your shift lever in the cabin; Ball in cup or blade in fork?
I am having trouble understanding your problem. Is it that you basically get front to back in one plane, 1-R, but that when you move the shift lever side to side you get no other gears? BUT, you can shift it outside by applying the pipe wrench? This last part would show that your tranny insides are fine and that your problem is out side the box. How is the shift coupler by the fire wall? Bushings installed, deteriorated? |
Lo-Fi Version | Time is now: 8th June 2024 - 09:56 AM |
