exhaust studs, question |
Ray Warren |
Jan 24 2004, 05:44 PM
Member Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None |
the exhaust studs that go into the head.
should i put med strength loctite or should i be putting anti sieze on them? also do i need to drop the oil to change the push rod tube seals? |
DNHunt |
Jan 25 2004, 08:11 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
I finally solved my exhaust leak with these 8mm X 9mm big ass exhaust studs. Inboard #3 stud always backed of so I finally drilled it to 5/16 and tapped it to fit 9mm. I also used red Locktite and torqued them to 18ftlbs
Dave Attached image(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 01:26 PM |
