exhaust studs, question |
Ray Warren |
Jan 24 2004, 05:44 PM
Member Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None |
the exhaust studs that go into the head.
should i put med strength loctite or should i be putting anti sieze on them? also do i need to drop the oil to change the push rod tube seals? |
rhodyguy |
Jan 25 2004, 09:56 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
then i presume you had to use washers. i don't like the way the ones you used sit on the flanges of the he's. the 1/4" drive socket worked well removing the 13mm nuts. if the studs are the right size i would like to get them. i going to call you.
kevin |
Lo-Fi Version | Time is now: 8th June 2024 - 11:42 AM |
