> Should/could I run new fuel lines some other place, Suggestions please...
Dave Cawdrey
post Mar 29 2003, 02:09 AM
Dumbo going poop, Daddy :)
I was thinkin heater channels/longs. Is this safe? Any other ideas? Clean and update existing??? (IMG:style_emoticons/default/confused24.gif)
Jus planing ahead... (IMG:style_emoticons/default/blink.gif)
Dave_Darling
post Mar 30 2003, 01:53 AM
914 Idiot
QUOTE(korijo @ Mar 29 2003, 06:58 PM)
Do the stock lines have any steel tubing, like where it exits tunnel under the tank? I have steel connections there. The existing plastic at the rear is brittle, broke already. Does this crap run all the way thru the tunnel and connect to the tubing/nipples I'm talking 'bout?
The stock lines are steel up front, where they go through the grommet. The plastic is (more or less) just pushed onto the steel bits, and then runs back through the tunnel and exits into the engine bay. There is practically never a problem with the lines in the tunnel, unless they get physically damaged by some intrusion. (Screw, drill bit, etc.) In the engine bay is another story. They get exposed to heat and chemicals and such, and can eventually get brittle and break. As long as you can safely get rubber lines onto them, I don't think there's a lot of problem just keeping them.
I'd use SS truck hard brake line. Aluminum and copper have too many potential issues. Copper in particular...
--DD
Dave Cawdrey   Should/could I run new fuel lines some other place   Mar 29 2003, 02:09 AM
Jeroen   Go for metal lines down the center tunnel... chee...   Mar 29 2003, 04:51 AM
URY914   I agree. In the center is the best place. Shortest...   Mar 29 2003, 06:13 AM
joea9146   Metal down the middle   Mar 29 2003, 07:51 AM
Dave Cawdrey   So, the group consensus is metal down the middle. ...   Mar 29 2003, 06:21 PM
ChrisReale   Stock fuel lines were hard plastic.   Mar 29 2003, 06:30 PM
anthony   I wouldn't replace them unless they need it. I...   Mar 29 2003, 06:30 PM
Jeroen   I'd have to disagree with Anthony... These pla...   Mar 29 2003, 06:47 PM
URY914   There was a post with this topic a few weeks back ...   Mar 29 2003, 07:05 PM
Dave Cawdrey     Mar 29 2003, 08:58 PM
anthony
  Mar 29 2003, 09:14 PM
jimtab   I say replace them, the job isn't that bad (ev...   Mar 30 2003, 01:19 AM
Dave_Darling     Mar 30 2003, 01:53 AM
Dave Cawdrey
- Lo-Fi Version Time is now: 15th July 2025 - 02:38 AM
