> OT: 2002 VW Jetta question: How do i turn off the headlights?
post Mar 3 2009, 09:21 PM
Resident German
So, i've got my 2002 Jetta for a little over a year now and the battery died on me this morning.
No big deal, i thought. Went to my local flaps and got a new one, replaced it, so far so good.
Then i went online and low and behold found out that my car seems to have a problem with the battery draining.
(IMG:style_emoticons/default/dry.gif)
Now, here's the question:
My car came with the "neat" feature of headlights that are always on. As soon as i turn the key, they light up, no matter if night or day.
How can i turn my headlights off so i can actually recharge the battery while driving during the day?
(IMG:style_emoticons/default/confused24.gif) Andy
ejm
post Mar 4 2009, 05:34 AM
I can see the light at the end of the tunnel
If you think it's a charging problem check the alternator cable. The crimped ends get corrosion inside causing high restistance. Also check the battery fuse box for bad connections and melting. Your car does not have a central electronics module like the later cars so the DRL's cannot be turned off using a scan tool.
SirAndy   OT: 2002 VW Jetta question: How do i turn off the headlights?   Mar 3 2009, 09:21 PM
r_towle   Google VAGCOM Download that and buy a cable from ...   Mar 3 2009, 09:24 PM
ArtechnikA   VAGCOM Download that and buy a cable from Ebay. ...   Mar 3 2009, 09:40 PM
scotty   VAGCOM Download that and buy a cable from Ebay....   Mar 3 2009, 10:45 PM
ArtechnikA   Would the VAGCOM (Ross-Tech) and cable be a must ...   Mar 4 2009, 06:26 AM
sendjonathanmail   yep, thats what works on my jetta.   Mar 3 2009, 10:13 PM
effutuo101   It is designed to run with the headlights on. I w...   Mar 3 2009, 10:31 PM
arvcube   some folks have pulled relay 173 out (DRL). Not s...   Mar 4 2009, 12:26 AM
ejm   If you think it's a charging problem check the...   Mar 4 2009, 05:34 AM
SirAndy   If you think it's a charging problem check th...   Mar 4 2009, 12:59 PM
ejm   Mhmmm. I get 14.5V across the terminals when the ...   Mar 4 2009, 05:20 PM
McMark   If the current being produced by the alternator is...   Mar 4 2009, 03:11 PM
Cap'n Krusty   After reading through this thread, I've notice...   Mar 4 2009, 05:36 PM
MDG   as always the Cap'n is spot on; DRL's have...   Mar 4 2009, 05:46 PM
pete-stevers   bash em out....and throw it out i will never own a...   Mar 4 2009, 06:25 PM
Cap'n Krusty   I work on post 2000 (A4) J/G/NBs all the time, oft...   Mar 4 2009, 06:41 PM
sww914   I think I'd use a 5 iron.   Mar 4 2009, 11:29 PM
highways   Disconnect the low beam power cable, splice it int...   Mar 5 2009, 02:54 AM
Vacca Rabite   Disconnect the low beam power cable, splice it in...   Mar 5 2009, 07:51 AM
- Lo-Fi Version Time is now: 17th July 2025 - 05:05 AM
