carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 125,886 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
Found out today that while the shop was working on my 914-6, one of the flunky's remove & destoyed my sticker from the door-jam. I had made it Perfectly Clear that this sticker was not to be touched and to be protected during the restoration. But now it's gone. (IMG:style_emoticons/default/mad.gif)
I was told that you can get them from Porsche? (IMG:style_emoticons/default/confused24.gif) I know that George sells replicas, but how do you get them perforated? Pissed & confused in Tampa, T.C. ![]() ![]() |
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
If the tamper proof circles are 5mm then could you make a die with 28 holes, skip the next offste row down and do the next in the skip a line pattern with 4 or 5 rows down. Then put a piece of dense rubber pad under it. Make a position jig bottom that you could move the top plate down one row and 1/2 hole to the side to do the other 1/2 set of embosses. the punch itself could be maybe the biopsy punch some one already mentioned or to keep from cutting out a hole a .002 hollow in the center of the punch to keep from going too deep.
After looking at the embossed holes they are touching so the holes in a row won't work. It would have to be every other hole which is getting more complicated. |
Lo-Fi Version | Time is now: 4th July 2025 - 03:27 PM |
