> 914 stiffening for street use, revisiting old threads
BGman
post Jan 23 2004, 10:15 AM
Greg
I have been reading through lots of old discussions from you all on how to do this.
It is all very interesting. You guys have some extreme set-ups. I am really wanting to keep the outside appearance very clean and stock looking.
Here is what I have picked up as being the best ideas so far:
1. Repair (cut/weld) any part of the longitudinals that have been compromised. Just a small area on the passenger side- already working on it.
2. Weld in 16 guage steel along the interior of the car (inside long) from one wheel well...around the firewall...and to the other wheel well.
3. Pay particular attention to the area where this piece fits into the corner that joins the long to the rear firewall. (Add horizontal triangle bracing if possible in the corner??)
4. Weld in a small frame into the engine compartment. Square tubing across the upper part of the firewall, under the hinges of the engine lid, and downtubes that connect it to ??? How and where will the downtubes connect? The car is stock, so I cannot go all the way to the rear shock towers.
What size/type of square tubing is fine for the engine bay area?
Thanks.
BGman
post Jan 27 2004, 06:57 AM
Greg
Ok, here is the passenger side all tacked into place- have to make sure that it will clear the carbs on the engine, that I can remove/install the battery, and that I can get the engine lid back in place.
I welded a piece of 1 1/2" steel el (very securely) onto the frame where the downtubes connect. Hopefully, this will give it a strong bracing point. This location was the highest point on the framerails that I could get with all of the battery/trunk hardware staying in place.
-g
BGman   914 stiffening for street use   Jan 23 2004, 10:15 AM
URY914   I haven't heard of #4 before. Paul   Jan 23 2004, 10:57 AM
seanery   there was a thread somewhere where it was mentione...   Jan 23 2004, 11:21 AM
Jeroen   I think it was Brad who mentioned a set up like th...   Jan 23 2004, 11:36 AM
d914   it was brad: Square tube across the firewall and ...   Jan 23 2004, 11:43 AM
BGman   So you guys have never seen it actually done? I t...   Jan 23 2004, 01:06 PM
Mueller   it's been done, one person(s) went so far as t...   Jan 23 2004, 01:38 PM
maf914   The Cobra chassis and other ladder type frames wer...   Jan 23 2004, 03:20 PM
nebreitling   i'm sure you have good reasons to create a sup...   Jan 23 2004, 04:03 PM
BGman   the latter- the engine bay is empty, it's col...   Jan 23 2004, 04:33 PM
BGman   Ok, here is the passenger side all tacked into pla...   Jan 27 2004, 06:57 AM
maf914   BGman, With carbs and the battery in the stock lo...   Jan 27 2004, 07:52 AM
Bleyseng   While you are at it, why not fix that shedded engi...   Jan 27 2004, 09:47 AM
BGman   The battery fits. I have measured and measured an...   Jan 27 2004, 04:57 PM
SirAndy   from your pic, it looks like you won't be able...   Jan 27 2004, 05:05 PM
DNHunt   Get a new engine shelf from Restoration Designs. ...   Jan 27 2004, 06:41 PM
vsg914   hey, where is Restoration Designs? Been trying to ...   Jan 27 2004, 06:44 PM
jkeyzer   Reinforcement = weight. I am thinking in 4 cylin...   Jan 27 2004, 06:59 PM
Bleyseng   I saw that too Andy,hehe... he's got some cutt...   Jan 27 2004, 07:18 PM
BGman   You guys had better give me a little more credit t...   Jan 27 2004, 10:47 PM
SirAndy     Jan 27 2004, 11:14 PM
Bleyseng   ok, ok, it was hard to tell cuz the pics looked li...   Jan 27 2004, 11:27 PM
BGman   I guess I could if I had the inclination to cut op...   Jan 29 2004, 10:14 PM
- Lo-Fi Version Time is now: 14th March 2026 - 09:29 AM
