thesey914 |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 ![]() ![]() |
My engine is not starting, I have fuel but it seems no spark. Changed the ignitor back to points and still no luck.
I'm suspecting the coil -its one of those bosch blue coils. I seem to remember that the blue coil has a ballast resistor so values between the contacts should be about 3-5 ohms. What is the rating for contact and the main lead terminal .....does the resistor affect this value? I have 10k upwards in my mind. Anyone one have any numbers or advice? (IMG:style_emoticons/default/wacko.gif) Update....I have just read that one shouldn't use a conventional coil with a CD ignition unit.....which I have just hooked up. Perhaps I've blown it up |
Kargeek |
Senior Member ![]() ![]() ![]() Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 ![]() |
Using a stock type coil with a CD ignition...well, it depends on the mfg of the CD unit. I had an older permatune unit, new in the box and it says to use a new stock type coil. I'm told that the bosch blue one is OK to use. Maybe your old coil just gave up. Dave
Lo-Fi Version | Time is now: 11th July 2025 - 12:39 PM |
