| BGman |
Jan 23 2004, 10:15 AM
Greg ![]() ![]() Group: Members Posts: 87 Joined: 18-January 04 From: Owensboro, KY Member No.: 1,575 Region Association: None |
I have been reading through lots of old discussions from you all on how to do this.
It is all very interesting. You guys have some extreme set-ups. I am really wanting to keep the outside appearance very clean and stock looking. Here is what I have picked up as being the best ideas so far: 1. Repair (cut/weld) any part of the longitudinals that have been compromised. Just a small area on the passenger side- already working on it. 2. Weld in 16 guage steel along the interior of the car (inside long) from one wheel well...around the firewall...and to the other wheel well. 3. Pay particular attention to the area where this piece fits into the corner that joins the long to the rear firewall. (Add horizontal triangle bracing if possible in the corner??) 4. Weld in a small frame into the engine compartment. Square tubing across the upper part of the firewall, under the hinges of the engine lid, and downtubes that connect it to ??? How and where will the downtubes connect? The car is stock, so I cannot go all the way to the rear shock towers. What size/type of square tubing is fine for the engine bay area? Thanks. |
| SirAndy |
Jan 27 2004, 05:05 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,458 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
from your pic, it looks like you won't be able to get the engine-lid back on.
the lid flange slides UNDER that hinge, then the bolt is inserted from below ... looks like a solid bracing otherwise, Andy |
BGman 914 stiffening for street use Jan 23 2004, 10:15 AM
URY914 I haven't heard of #4 before.
Paul Jan 23 2004, 10:57 AM
seanery there was a thread somewhere where it was mentione... Jan 23 2004, 11:21 AM
Jeroen I think it was Brad who mentioned a set up like th... Jan 23 2004, 11:36 AM
d914 it was brad:
Square tube across the firewall and ... Jan 23 2004, 11:43 AM
BGman So you guys have never seen it actually done? I t... Jan 23 2004, 01:06 PM
Mueller it's been done, one person(s) went so far as t... Jan 23 2004, 01:38 PM
maf914 The Cobra chassis and other ladder type frames wer... Jan 23 2004, 03:20 PM
nebreitling i'm sure you have good reasons to create a sup... Jan 23 2004, 04:03 PM
BGman the latter-
the engine bay is empty, it's col... Jan 23 2004, 04:33 PM
BGman Ok, here is the passenger side all tacked into pla... Jan 27 2004, 06:57 AM
maf914 BGman,
With carbs and the battery in the stock lo... Jan 27 2004, 07:52 AM
Bleyseng While you are at it, why not fix that shedded engi... Jan 27 2004, 09:47 AM
BGman The battery fits.
I have measured and measured an... Jan 27 2004, 04:57 PM
DNHunt Get a new engine shelf from Restoration Designs. ... Jan 27 2004, 06:41 PM
vsg914 hey, where is Restoration Designs? Been trying to ... Jan 27 2004, 06:44 PM
jkeyzer Reinforcement = weight. I am thinking in 4 cylin... Jan 27 2004, 06:59 PM
Bleyseng I saw that too Andy,hehe... he's got some cutt... Jan 27 2004, 07:18 PM
BGman You guys had better give me a little more credit t... Jan 27 2004, 10:47 PM
Bleyseng ok, ok, it was hard to tell cuz the pics looked li... Jan 27 2004, 11:27 PM
BGman I guess I could if I had the inclination to cut op... Jan 29 2004, 10:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 09:29 AM |
