| Roy |
Mar 15 2009, 04:24 PM
Newbie ![]() Group: Members Posts: 39 Joined: 7-November 05 From: Vancouver, BC Member No.: 5,083 Region Association: None |
Hiya fellas, I've got the unique opportunity of having two parts cars both with full A/C. One car has the VPC system and the other a DPD. Both systems look ok but I will likely send them out for refurbishment. So overall I'm wondering which system to go with? This will be in to a '73 2.0. I don't mind cutting up the car to fit the system as I will go about it much more gingerly than the dealers originally did and I will make sure to rust-proof my cuts. Are the differences mostly aesthetic? Does one system give more luggage space than the other? Does one cool better? Does one have a nicer install or require less cutting? Is one more 'correct' for a '73? This is not a question of whether I should or should not. My mind is made up and I have read enough posts to know that when in good working condition a 914 A/C system can make my girlfriend's important bits look 'perky' so please don't try to dissuade me. I am aware of the high horsepower consumption of the system and the availability of newer, more modern systems. I want a period correct, close to stock A/C system with the least possible modern upgrades for usefulness. A/C enthusiasts please reply!
| charliew |
Mar 27 2009, 10:10 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
I'm not sure which under dash unit I have but a sticker on the inside says Ft. Worth, TX. When I got it I took it apart to clean it up and found the sticker loose in the bottom. Once I got it apart I found the temp control switch had the cover removed and the adjustment screws have been turned. The cover is missing so I thought I would get a replacement switch but it has a square shaft for the knob and so far I haven't found that type of switch. I might be able to put the original knob on the d shaped shaft of the replacement I found but it will require a little shadetree engineering. I may try to check the switch with a meter. It should open the circuit to the compressor at 33 degrees I guess to keep the evaporator from freezing up. Replacement parts for these aftermarket units may be interesting.
I may have gotten lucky the other day. I went to a local tube and fitting supplier for some hydraulic fittings and the counterman is a old vw ac man and he remembers a lot about the dealer addon ac stuff. He said he thought the dpd was made in Ft. Worth. I realize the vw is not a 914 but I have a 72 super beetle with ac and it's very similiar to the 914. The 914 type 4 has a lot better mounting design for the compressor than the bug though. |
Roy 35 Years Later: VPC or DPD A/C? Mar 15 2009, 04:24 PM
Thomas J Bliznik Hi Roy,
AC in your 914 is a great project. I... Mar 15 2009, 09:03 PM
southernmost914 Lots of posts :agree: The DPD condesor allows for... Mar 17 2009, 04:17 PM
rfuerst911sc The York compressor is good as a boat anchor and t... Mar 17 2009, 06:36 PM
charliew There is an adapter that goes on the york bracket ... Mar 19 2009, 12:28 AM
Roy Alright, since no one is expressing an overwhelmin... Mar 27 2009, 04:53 PM
southernmost914 My copy of the DPD owners Operating Instructions i... Mar 27 2009, 05:25 PM
3d914 Roy,
If you do a search for A/C and my member nam... Mar 27 2009, 07:24 PM
mtndawg How ironic that you're putting one in. I'm... Mar 27 2009, 07:46 PM
retrofit
Roy,
If you do a search for A/C and my member na... Mar 28 2009, 02:38 PM
904svo There is nothing that goes on there. It was only u... Mar 27 2009, 08:55 PM
Tom_T
Hiya fellas, I've got the unique opportunity ... Mar 31 2009, 01:08 AM
Tom_T
Hiya fellas, I've got the unique opportunity ... Mar 31 2009, 01:11 AM
Tom_T
Hiya fellas, I've got the unique opportunity ... Mar 31 2009, 01:38 AM
Roy Very Nice! Thanks Tom! Mar 31 2009, 12:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:10 PM |
