914 2.0 refuses to start |
Frank Lolkema |
Mar 28 2009, 05:40 AM
Newbie Group: Members Posts: 7 Joined: 29-July 05 From: holland Member No.: 4,503 |
I have a problem with my ´73 2.0 with the original fuel injection that drives me crazy!
I have completely overhauled the engine. After putting it back in I can not get it to start with the starter motor. The motor crancks but it will not start. When I pull it with another car it will start instantly. Using jumper cables from a car that is running at 3500 rpm does not help. Here is what I have done so far: Replaced the battery with a new one; Checked all the wires and connections, everything is set up correctly and the connectors are all oke, I´ve used contactspray on all contacts; Replaced the spark plugs with new ones, left the new ones in, put the old ones in the caps and crancked the engine, all spark plugs give a good fat spark; Set the timing; Replaced the starter motor with a different one; Checked the ground strap from the gearbox the the chassis; Attached a starter cable from the gearbox directly onto the negative lead off the battery to elimanate ground strap problems; Checked the fuel injectors, they all inject fuel when the enige is crancked; Put in fresh new fuel; Airfilter is new; I really don´t know what else to try. When the engine runs, it runs perfectly, very strong, no smoke, no misfires, no strange noises. When I switch it of warm it also refuses to be started in the conventional way. I really don´t know what else to look for, it drives me crazy! (IMG:style_emoticons/default/headbang.gif) Anybody have an idea of what I can/should look for? Frank |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:56 PM |
