My Cleanup & Detailing Thread |
jonferns |
May 5 2008, 08:07 PM
Advanced Member Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States |
I've been spending alot of my free time doing some detailing work in the wheel wells while the car was up on jackstands awaiting a replacement fuel pump. The idea was to detail the four wheel wells. On the fronts I was left with large dark spots where there was a thick buildup of road crud; the paint isn't chipped in those areas, and the spots come out when I scrape at them with my fingernail, but the spot is just too large to remove all of it that way. I was looking to see if anyone else has dealt with something like this. Maybe some sort of rubbing compound will contain just enough abrasives to remove it without harming the paint underneath? All in all, not bad for almost 40 year old paint in a vulnerable spot.
Also, the struts are left with some spots after cleaning them, what could I use to clean them up. Pat, think that "simichrome" would be a good idea to use on them? |
jonferns |
Mar 28 2009, 09:18 PM
Whew, finally finished cleaning the trans. 3 cans of EasyOff oven cleaner, a pressure washer spraying hot water, and a small toothbrush, it is spotless! Took me about 4-5 hours but I was able to achieve the spotless finish that I was after. After doing the oven cleaner twice, I scrubbed the entire thing with baking soda and water to neutralize any acid from the oven cleaner as to not discolor my case, just as a precaution. Im really happy with the results, every nut & bolt is clean. Now just to replace the speedo angle drive (looking for one!). Next task is cleaning up the mess under the car, but it will be as clean as my wheelwells. Pics to come, my hands were too greasy to take any.
Lo-Fi Version | Time is now: 31st May 2024 - 10:39 PM |
