rusty floors ? |
rusty floors ? |
evangojason |
Mar 30 2009, 08:33 PM
Newbie Group: Members Posts: 20 Joined: 15-August 07 From: wa. Member No.: 8,003 |
So I pulled everything out of the car and I'm cleaning up the floor boards and firewall and all the reat of that fun stuff. Got all the sound material out and now i'm removing paint and rust. What is the best way to get into the center section to clean it up? You know where the "tranny hump" would be. Is there a way to get in there? I've got alot of help reading threads to get to this piont but havent heard anyone mention this part of the floor.
drive-ability |
Mar 30 2009, 10:42 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
I'll jump in here, your talking about center tunnel and its mostly sealed not an easy place to work. I 'm sure others have tackled this area, but I has a little rust there and just cleaned as much as I could and sealed it with Por-15 a paint / sealer.
evangojason |
Mar 30 2009, 10:53 PM
I'll jump in here, your talking about center tunnel and its mostly sealed not an easy place to work. I 'm sure others have tackled this area, but I has a little rust there and just cleaned as much as I could and sealed it with Por-15 a paint / sealer. Thats what the plan was, should i just dump a good amount in there and let it spead itself into the areas I cant get to? Is it one over those things you do the best you can and try to forget about and hope it never comes back to haunt you? |
SirAndy |
Mar 30 2009, 11:12 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I'll jump in here, your talking about center tunnel and its mostly sealed not an easy place to work. I 'm sure others have tackled this area, but I has a little rust there and just cleaned as much as I could and sealed it with Por-15 a paint / sealer. Thats what the plan was, should i just dump a good amount in there and let it spead itself into the areas I cant get to? Is it one over those things you do the best you can and try to forget about and hope it never comes back to haunt you? No! I wouldn't dump POR-15 into the center tunnel ... If there is significant rust in there, it needs to be fixed the right way ( (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) ) ... If it's just surface rust, get a spray bottle, fill it with Metal Ready or Ospho and spray the heck out of the tunnel. Btw. your transmission is all the way in the back of the car, so no "tranny hump" in the cabin. (IMG:style_emoticons/default/shades.gif) Andy |
evangojason |
Mar 30 2009, 11:54 PM
I'll jump in here, your talking about center tunnel and its mostly sealed not an easy place to work. I 'm sure others have tackled this area, but I has a little rust there and just cleaned as much as I could and sealed it with Por-15 a paint / sealer. Thats what the plan was, should i just dump a good amount in there and let it spead itself into the areas I cant get to? Is it one over those things you do the best you can and try to forget about and hope it never comes back to haunt you? No! I wouldn't dump POR-15 into the center tunnel ... If there is significant rust in there, it needs to be fixed the right way ( (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) ) ... If it's just surface rust, get a spray bottle, fill it with Metal Ready or Ospho and spray the heck out of the tunnel. Btw. your transmission is all the way in the back of the car, so no "tranny hump" in the cabin. (IMG:style_emoticons/default/shades.gif) Andy Yes yes I know where my tranny is, just didn't know the name. But anyways, there is some "flaky" rust in there but poking around in there seems to be solid. So maybe vacume what i can, use compressor to try and spray the loose stuff to where I can get at it then metal prep? Thanks so much for the help, alittle suprised I couldnt find any talk about this with all I've read on cleaning and preping the floors. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:20 PM |
