Bad A-Arm flange, Need help |
VaccaRabite |
Mar 31 2009, 04:47 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
When I bought this car, it only had one of the two bolts holding in the forward drivers side a -arm attacment point (where it attaches to the body under the front trunk.)
I figured it was just due to the accident that had taken place at some point in the car's past, and during the repair the mount offset a little. Well, I was probably right, but not how I figured. Once I got a good look at everything, this is what I saw: (IMG:http://farm4.static.flickr.com/3465/3402174275_62d39408f8.jpg) (IMG:http://farm4.static.flickr.com/3572/3402979354_5ddb0daca4.jpg) As you can see the flange on the A-Arm right behind the mounting point is buggered. Inverted. And it is pushing against the bushing and holding the mount out of location. So. How do I fix it? even with a BFH I was not able to knock the mount off the bushing. I DO NOT want to drop the A-Arm. I just got everyhting put back together, and removing all of the front suspension is more then I can fathom right now. Other alternative is that I could just continue driving on one bolt, as the PO must have been doing. This car is just determined to stay home from Hershey. At least I got my brakes up and working. Zach |
VaccaRabite |
Mar 31 2009, 05:21 PM
Can I pull the A Arm out w/o dropping the entire front suspension? I really don't want to have to pull the Master Cylinder and undo all my brake line fittings. That is a really hateful job, and I JUST got it all put back together.
Zach |
ArtechnikA |
Mar 31 2009, 05:38 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
Can I pull the A Arm out w/o dropping the entire front suspension? Sure - done it... either disconnect the strut from the ball joint or the ball joint from the A-arm. and pull the tie rod end. At that point, the A-arm is just held in its mounts. You may have a challenge getting the torsion bar out if there's any bending - I really had to wail on one from California no less and there was no bending at all... |
Lo-Fi Version | Time is now: 11th June 2024 - 05:52 AM |
