Fuel tank question?, Two lines on bottom right... |
jcambo7 |
Apr 3 2009, 09:34 AM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
I am trying to figure out what these two lines would go to on the bottom right of my fuel tank. I am guessing they go to tunnel lines but I am not for sure. (IMG:style_emoticons/default/confused24.gif)
This is a picture of where the lines would be at if the tank was in it's spot. I am guessing the lines go through the small hole but I don't know. (IMG:style_emoticons/default/confused24.gif) |
SirAndy |
Apr 3 2009, 11:30 AM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
And the two lines are different in size, the larger being the supply line to the fuel filter and fuel pump, the smaller one being the return line.
You car won't run right if you hook them up incorrectly ... (IMG:style_emoticons/default/popcorn[1].gif) Andy |
jcambo7 |
Apr 3 2009, 11:44 AM
And the two lines are different in size, the larger being the supply line to the fuel filter and fuel pump, the smaller one being the return line. You car won't run right if you hook them up incorrectly ... (IMG:style_emoticons/default/popcorn[1].gif) Andy Thanks Andy! (IMG:style_emoticons/default/beerchug.gif) That helps out a lot. |
Lo-Fi Version | Time is now: 7th June 2024 - 04:48 AM |
