Shifting issue..., Clutch is not working. |
bmtrnavsky |
Apr 2 2009, 09:38 PM
Member Group: Members Posts: 355 Joined: 20-October 07 From: Longview, TX Member No.: 8,245 Region Association: Southwest Region |
Ok, I have a problem and I am not sure what the issue is. I was driving and everything was just fine when I downshifted from 3rd to 2nd and let the clutch out and there was nothing. I can freely shift the car without pressing the clutch at all. I can feel the gears changing, so it does not seem to be a shift linkage issue. When I press the clutch it feels dead like there is nothing there and the clutch is disengaged.
Any ideas thoughts or suggestions? |
maf914 |
Apr 3 2009, 02:44 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Many, many years ago, when my car had only about 55k miles, my clutch failed. I was near home, less than a mile, when as I shifted up I felt a light thump through the clutch pedal. The clutch began slipping and although I could change gears no gear provided solid drive. I was able to drive very slowly home.
When I dropped and split the engine and tranny I found the diaphragm spring in the pressure plate had cracked radially. The pressure plate had lost it clamping ability as a result. I wonder if this could have happened to your clutch. |
Lo-Fi Version | Time is now: 6th June 2024 - 07:39 PM |
