The torsion bar adjusting bolt is stuck(rusted) |
turnaround89 |
Apr 6 2009, 12:38 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
I need to lower the front end of my car but the adjusting bolt on both sides is rusted stuck. Ive been spraying liquid wrench to hopefully loosen up some of the rust, i think i might have rounded out the inside of the passenger side because it is stuck. What can i do? can i grind down two sides of the bolt head and get a wrench on it to loosen it up?
turnaround89 |
Apr 6 2009, 12:47 PM
If i weld a bolt onto the adjusting bolt and get it turn, what would happen if i completely remove the adjusting bolt to put a new one in?
6freak |
Apr 6 2009, 01:13 PM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
If i weld a bolt onto the adjusting bolt and get it turn, what would happen if i completely remove the adjusting bolt to put a new one in? well you should be at the point the cars off the ground and wheels off right! when you take that bolt out all it will do is relaxe the torsion bar...and if your at that point remove said bar and lube and check for cracks.do one side at a time so`s to not mix them up!(should be stamped anyway) when your satisfied there ok reinstall bar and new ajustment bolt....remember where the cap was and how many threads were showing on the bolt That will get you close ..then corner balance.....I hope thats correct....the pros will jump in soon |
Lo-Fi Version | Time is now: 1st June 2024 - 06:06 AM |
