> Subie swap thought?, cooling options
evangojason
post Apr 7 2009, 12:37 AM
been looking on the site and cleaning up the floor in my 75 914 that will some day
be water cooled and a question poped into my head. why run the water lines in the center tunnel? Couldnt I use the space currently occupied by the air tubes? Has this been done? I searched and everyone with a radiator up front runs them down the center. There would be no use for the air tubes. Just a thought.
dlo914
post Apr 7 2009, 01:40 AM
Whatchu' lookin' at?!?!
We don't suggest running the water lines in the center tunnel, because the shift linkages and rod occupy the space. There have been a few that have gone the longs (heater tubes) route, but the easiest route would be to run underneath the car in the provided groves. I think it was Ahmenson that ran the water lines in the longs. Search for his name it should be in his project thread.
And...
evangojason   Subie swap thought?   Apr 7 2009, 12:37 AM
dlo914   We don't suggest running the water lines in th...   Apr 7 2009, 01:40 AM
evangojason   We don't suggest running the water lines in t...   Apr 7 2009, 01:49 AM
evangojason   well did the search for his name and nothing but t...   Apr 7 2009, 02:35 AM
pktzygt   well did the search for his name and nothing but ...   Apr 7 2009, 10:02 AM
DBCooper   Rod Simpson popularized the V8 swap what, twenty-f...   Apr 7 2009, 04:33 AM
Zaney   Here is Scott's (Amenson) PorSti Thread PorSt...   Apr 7 2009, 08:55 AM
charliew   If you are going to use the suby tranny you will p...   Apr 7 2009, 09:30 AM
charliew   Aluminum will cool faster than iron but horsepower...   Apr 7 2009, 10:22 AM
pktzygt   Aluminum will cool faster than iron but horsepowe...   Apr 7 2009, 10:54 AM
charliew   The only thing I don't particularly like about...   Apr 7 2009, 11:06 AM
cobra94563   1 inch lines - same as if rubber hose was used. ...   Apr 8 2009, 01:59 PM
cobra94563   Hi, I have a V8 conversion and ran the lines thru ...   Apr 7 2009, 05:46 PM
charliew   Hi, I have a V8 conversion and ran the lines thru...   Apr 8 2009, 12:49 AM
evangojason   Once again alot of good ideas and thoughts to cons...   Apr 7 2009, 09:19 PM
pktzygt   I see alot of guys running a piece of wood between...   Apr 8 2009, 02:47 PM
evangojason   yeah, ive seen that but most of it was when on a r...   Apr 8 2009, 03:12 PM
d914   no flames please , but I still keep looking at the...   Apr 8 2009, 03:35 PM
plymouth37   I wouldn't recommend running the hoses through...   Apr 8 2009, 03:45 PM
pktzygt   I thought the PorSTi thread was on to something, b...   Apr 8 2009, 06:15 PM
charliew   He is also using 1.750 and 1.50 id lines I think. ...   Apr 8 2009, 08:26 PM
PanelBilly   If your going to change the car that much, why not...   Apr 8 2009, 09:08 PM
charliew   The most pressure on the car is in the front. It w...   Apr 8 2009, 09:19 PM
- Lo-Fi Version Time is now: 8th July 2025 - 08:28 PM
