> Subie swap thought?, cooling options
evangojason
post Apr 7 2009, 12:37 AM
been looking on the site and cleaning up the floor in my 75 914 that will some day
be water cooled and a question poped into my head. why run the water lines in the center tunnel? Couldnt I use the space currently occupied by the air tubes? Has this been done? I searched and everyone with a radiator up front runs them down the center. There would be no use for the air tubes. Just a thought.
charliew
post Apr 7 2009, 09:30 AM
If you are going to use the suby tranny you will probably be using a cable shifter so there won't be a shifter shaft in the tunnel. Also I would not put the fuel lines alongside the coolant lines in the tunnel. I think I will use the tunnel as it seems to be the cleanest routing I can come up with and I've been studying it quite awhile. I'll still have to look at the rack area and into the front trunk approach to make my final decision. If I use the tunnel it will have a open bottom to help release the heat. Or put a louvered cover on it to be really fancy. It seems a galvanized c shaped cavity would be the cats meyow. Like a galvanized 2x6 metal building perling except with the lips turned out instead of in. I will just get a sheetmetal shop to make it and weld it in. It should be even stronger than the original.
evangojason   Subie swap thought?   Apr 7 2009, 12:37 AM
dlo914   We don't suggest running the water lines in th...   Apr 7 2009, 01:40 AM
evangojason   We don't suggest running the water lines in t...   Apr 7 2009, 01:49 AM
evangojason   well did the search for his name and nothing but t...   Apr 7 2009, 02:35 AM
pktzygt   well did the search for his name and nothing but ...   Apr 7 2009, 10:02 AM
DBCooper   Rod Simpson popularized the V8 swap what, twenty-f...   Apr 7 2009, 04:33 AM
Zaney   Here is Scott's (Amenson) PorSti Thread PorSt...   Apr 7 2009, 08:55 AM
charliew   If you are going to use the suby tranny you will p...   Apr 7 2009, 09:30 AM
charliew   Aluminum will cool faster than iron but horsepower...   Apr 7 2009, 10:22 AM
pktzygt   Aluminum will cool faster than iron but horsepowe...   Apr 7 2009, 10:54 AM
charliew   The only thing I don't particularly like about...   Apr 7 2009, 11:06 AM
cobra94563   1 inch lines - same as if rubber hose was used. ...   Apr 8 2009, 01:59 PM
cobra94563   Hi, I have a V8 conversion and ran the lines thru ...   Apr 7 2009, 05:46 PM
charliew   Hi, I have a V8 conversion and ran the lines thru...   Apr 8 2009, 12:49 AM
evangojason   Once again alot of good ideas and thoughts to cons...   Apr 7 2009, 09:19 PM
pktzygt   I see alot of guys running a piece of wood between...   Apr 8 2009, 02:47 PM
evangojason   yeah, ive seen that but most of it was when on a r...   Apr 8 2009, 03:12 PM
d914   no flames please , but I still keep looking at the...   Apr 8 2009, 03:35 PM
plymouth37   I wouldn't recommend running the hoses through...   Apr 8 2009, 03:45 PM
pktzygt   I thought the PorSTi thread was on to something, b...   Apr 8 2009, 06:15 PM
charliew   He is also using 1.750 and 1.50 id lines I think. ...   Apr 8 2009, 08:26 PM
PanelBilly   If your going to change the car that much, why not...   Apr 8 2009, 09:08 PM
charliew   The most pressure on the car is in the front. It w...   Apr 8 2009, 09:19 PM
- Lo-Fi Version Time is now: 8th July 2025 - 08:36 PM
