How do you get the metal piece over the valve cover, Is there a secret to this? |
turnaround89 |
Apr 7 2009, 12:42 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
I did a valve adjustment today(first one ever (IMG:style_emoticons/default/piratenanner.gif) ) went really well up until the point the valve covers went back on. I have been fighting with the piece of metal that goes over the valve cover for hours and they won't go, what am i doing wrong? (IMG:style_emoticons/default/headbang.gif)
turnaround89 |
Apr 7 2009, 02:42 PM
I finally got it (IMG:style_emoticons/default/piratenanner.gif) , i went about the process all wrong when i started (IMG:style_emoticons/default/headbang.gif) . I put one side in and then tried to get the other side to pop into the hole. However, with your guys' advice you put the bail in both holes first then swing the bail over the valve cover and push up until it snaps into place. thanks everyone, i now know this for future valve adjustments.
Randal |
Apr 7 2009, 02:47 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
I finally got it (IMG:style_emoticons/default/piratenanner.gif) , i went about the process all wrong when i started (IMG:style_emoticons/default/headbang.gif) . I put one side in and then tried to get the other side to pop into the hole. However, with your guys' advice you put the bail in both holes first then swing the bail over the valve cover and push up until it snaps into place. thanks everyone, i now know this for future valve adjustments. Now if you have any oil leaks from the valve covers I have a great solution that works perfectly every time. The solution is actually from Mike K. editor and publisher of the 914 Magazine. |
Lo-Fi Version | Time is now: 7th June 2024 - 01:54 AM |
