engine overhaul or swap?, engine choice on a rebuild |
timofly |
Mar 31 2009, 07:50 PM
Member Group: Members Posts: 164 Joined: 21-February 09 From: VA Member No.: 10,082 Region Association: MidAtlantic Region |
We have a 1974 914 2.0 in need of an engine. The car has been sitting for 30+ years. It will run, sort of, but leaks oil like a cardboard tanker. The F.I. checks out electrically, but the engine won't accelerate. So, if we have to fool around with it, we should consider the following choices:
1. overhaul the existng engine 2. replace the engine with a rebuild from ? 3. try to resurrect the F.I. 4. just carburate it. Who has experience with overhaulers they'd share? How about "new" engine providers? I gather from some postings here that "Import World" doesn't enjoy lots of support from this group? Who else? We are looking for a stock engine or maybe a mild warming for street use. What say you, O Mighty Tribe? |
r_towle |
Apr 7 2009, 06:20 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
When I find these old motors, I typically pull the motor and replace all the seals.
Front and rear main seals. Push rod tube seals. Oil pressure sensor Oil cooler seals Fuel Injector seals Valve cover gaskets. Oil sump gaskets Oil temp gaskets (if so equipped) I also remove the head tin and clean all the flamable mouse nests that are in there before they catch fire. I would suggest that you do a leak down test to see how well it holds a seal...then go from there. If you want a turn key motor, McMark will do one for you...PM him. Jake Raby also does turn key motors, but those are bigger. For local shops, you need to track down Ray Mital..he is around here somewhere and he knows alot of the shops in NJ and NY Rich |
Lo-Fi Version | Time is now: 7th June 2024 - 09:55 PM |
